Light bar power source question
Discussion in '2.5 Gen Tundras (2014-2021)' started by Stocky Balboa, Oct 30, 2019.
  1. Oct 30, 2019 at 3:43 PM
    Stocky Balboa
    Stocky Balboa [OP] New Member
    OC , CA
    2018 Limited TRD 4x4 CM - Cement
    Minor stuff- Tint, rear sway bar , pedal commander, TRD drop in filter DD Exhaust, Bilstein 6112/5160, stealth 32” lightbar, Cali Raised Offroad fog light replacements.
    Dumb question but oh well, being overly cautious.
    What’s a good place to tap in the engine fuse box location
    so my lightbar only gets power when I have the ignition or ACC on?
    The harness says connect to battery but I don’t want the switch to have constant power.
  2. Oct 30, 2019 at 3:48 PM
    TokerJoker
    TokerJoker ΜΟΛΩΝ ΛΑΒΕ
    Travis
    Nowhere, Specific
    2014 Black SR5 4.6 Dbl Cab
    None.....yet
    Connect the positive terminal to the battery and put the switch on the negative side.
  3. Oct 30, 2019 at 4:12 PM
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
    I used high beam so the light bar only comes on when I turn on the high beam.
  4. Oct 30, 2019 at 5:14 PM
    Shark Bait
    Shark Bait Not new anymore
    David
    2019 Platinum
    Run the light bar to the battery through a relay, trigger the relay through a toggle switch off of an accessory source. Fuse both power feeds accordingly, to draw of bar and the relay can be triggered with a fuse 1-2 amp fuse.
  5. Oct 30, 2019 at 5:36 PM
    Stocky Balboa
    OC , CA
    Thank you.
    If I understand, with this done when the truck is off the lightbar cannot he turned on?
  6. Oct 30, 2019 at 6:14 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Depends on what source you use. I run mine through an alternate fuse block.
  7. Oct 30, 2019 at 6:34 PM
    Stocky Balboa
    OC , CA
    That’s what I’m getting at. Instead of running the power source directly to the battery then the relay, can I add a circuit in the engine bay fuse box to an existing accessory that’s only hot when the ignition is on
  8. Oct 30, 2019 at 6:37 PM
    Stocky Balboa
    OC , CA
    I’ll have to get some pictures, I think I’m making this harder then it is haha.
  9. Oct 30, 2019 at 6:40 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Like an Add-A-Fuse? Don’t see why not.
  10. Oct 30, 2019 at 6:47 PM
    Stocky Balboa
    OC , CA
    Yes. Just not sure which fuse to safely add too.
  11. Oct 30, 2019 at 7:22 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Add fuses run a sep fuse for both accessories so as long as you’re fused correctly for both it shouldn’t matter
  12. Oct 30, 2019 at 10:23 PM
    Shark Bait
    David
    2019 Platinum
    Correct, you don’t want to pull the amperage that a light bar can pull through your factory fuseblock. The relay feed comes from the battery with the correct amperage fuse but the your toggle switch with a low amperage fuse would feed the switching side of the relay via an accessory source circuit (like the power port circuit).
  13. Oct 31, 2019 at 12:16 AM
    Genuine Cooling Systems
    Genuine Cooling Systems New Member Vendor
    Just get a good harness with a fuse integrated like doide dynamics, then, put a aftermarket switch in the cab. It will turn on when the ignition is off but it's not going to drain the battery with it off.
  14. Oct 31, 2019 at 2:51 AM
    bradleykd
    bradleykd New Member
    Brad
    Kentucky
    2016 Limited-BLACK
    You can use anything for the switch power (coil) side of the relay. The fuse for the cigarette lighters will not come on unless the key is on. I used my highbeam wire. When I turn on my high beams, my light bar comes on.
