Light Bar connected to Brights
Discussion in 'Lighting' started by cwoodyfly, May 11, 2017.
  1. May 11, 2017 at 5:04 PM
    cwoodyfly
    cwoodyfly [OP] New Member
    2017 White Tundra
    I have installed a 30" and a 40" rigid light bars. Absolutely love them but was wondering if anyone had an idea how to wire the light bars to be turned on with bright lights? Basically i would like the brights to work normal for road use but turn the light bar switch to on, the bars would turn on when brights are activated. Has anyone tried this?
    Thanks
    Chris in washington
    Les7311 likes this.
  2. May 13, 2017 at 7:34 PM
    GavinG83
    GavinG83 New Member
    Gavin
    Wilmington, NC
    2000 Tundra SR5
    You just need to use a relay and have it wired up to a switch. I have not done it but I don't see why it wouldn't work.
    Pin
    30 to 12 volt power
    85 to ground
    86 hibeam trigger
    87 output to switch
    NewImprovedRon likes this.
  3. May 13, 2017 at 7:44 PM
    cwoodyfly
    2017 White Tundra
    Thanks.
    I already have the relay just need to dive in i guess
    Thats what i thought. The pin numbers will be a huge help.
  4. May 13, 2017 at 7:47 PM
    GavinG83
    GavinG83 New Member
    Gavin
    Wilmington, NC
    2000 Tundra SR5
    I think they are the correct pinouts but I don't have one in front of me hopefully someone can correct me if I'm wrong. Just make sure you put some fuses inline and you should have no problems.
  5. May 13, 2017 at 8:04 PM
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    When I installed my 40" NSV auto hood bulge lightbar they have specific directions on the wire to tie into for this feature. I used t taps and connected into a wire thats located behind the steering wheel column. Let me get the instructions and post them.
    GNTundra likes this.
  6. May 13, 2017 at 8:07 PM
    1UPPER
    TEXAS
    Flux capacitor!
    Yes. The only way my upper hood bulge lightbar works is if the high beams are activated. They did it this way for a safety feature.
  7. May 13, 2017 at 8:08 PM
    1UPPER
    TEXAS
    Flux capacitor!
    Flashing your high beams does not trigger the lightbar either. You have to have your high beams turned completely on.
  8. May 13, 2017 at 8:23 PM
    1UPPER
    TEXAS
    Flux capacitor!
    It's more involved than I previously remembered to do this. The lightbar I installed has plugs and harnesses made to plug into the stock harness in the steering column. Here are the photos Incase you want to try this. IMG_7572.jpg IMG_7573.jpgIMG_7574.jpg IMG_7575.jpg
