Lift & Tires Q
Discussion in 'Suspension' started by BRP479, Feb 19, 2020.
  1. Feb 19, 2020 at 5:35 PM
    BRP479
    BRP479 [OP] New Member
    Ricky
    Rogers,AR
    I’ve searched a lot on here and Tundratalk and haven’t found what I need. I do not off-road and looking for the smoothest ride.
    wheels are TSS 20” -50 offset
    Current tires are 285 55R20 BF KO2 AT
    Suspension: black SR5 shocks and TRD rear sway
    Considering either 6112/5160 with some shims/shackles or Toytec Eibach 3” lift. Also considering 1.25” spidertrax spacers
    what is the biggest tire I can fit? Right now I’m leaning towards 275 60R20s but want to go as big as I can. Don’t want to deal with trimming plastic
    thanks!
  2. Feb 19, 2020 at 5:49 PM
    Dropping to an 18 inch wheel will help the ride some. I would get a different offset before wheel spacers. Spidertrax are good, but I wouldn't use them with a lift.
  3. Feb 19, 2020 at 5:52 PM
    Also, a 275 is a little narrow for a 3 inch lift. I run a 3/2 lift with 285/70/18 Ridge Grapplers on an 18x9 0 offset.
  4. Feb 19, 2020 at 6:53 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Agree, moving to 18 inch wheels will give a better ride. And for best ride, stick with standard load tires. 275/65 18 has SL options. Anything bigger and you will likely be E load which will ride stiffer.
  5. Feb 20, 2020 at 9:48 AM
    BRP479
    Ricky
    Rogers,AR
    Would like to stick to the TSS 20s to save cost. But may look at 18s later for sure
