Lift & Tires coming - will I have traction control issues?
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by jetso, Dec 2, 2021.
  1. Dec 2, 2021 at 8:47 PM
    jetso
    jetso [OP] New Member
    Jetso
    2021 Tundra Limited (OR)
    Hey all! Hope everyone is doing well. I'm going to be installing the following soon.
    • 3.5 in front lift
    • 1.75 rear lift (CB shackles)
    • 295/70/18 tires on stock wheels with +60 offset.
    I've been told I'll still have a slight rake maintained. I've been reading older forms (2008-2018) and it seems like some people have issues with their traction control system turning on and limiting power at certain angles/turns.
    Is this something you've ran into or had friends run into? Is this of concern on 2021 models?
    Thank you in advance for reading through this! Appreciate your help.
    Akaklutz likes this.
  2. Dec 2, 2021 at 9:00 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    With 60 offset wheels and those tires, you will most likely rub the UCA in some situations, if not all the time. With spacers you should be golden
  3. Dec 4, 2021 at 5:39 AM
    jetso
    Jetso
    Thanks @MadMaxCanon. In conversation, I think the wheel/tire combo should fit without any rubbing on the UCA's. However, my main concern is not that, it's if the lift/tires is going to introduce any traction control/ABS/ACC issues. Have you experienced any of these?
  4. Dec 4, 2021 at 6:21 AM
    I'm on a 4/2 and no issues at all. TSS is fine as well.
    D4x4TRD likes this.
  5. Dec 4, 2021 at 12:19 PM
    Hunter10mm
    Hunter10mm New Member
    2021 DCLB
    Coming
    Mine rubbed with that combo and I looked everywhere for answers ahead of time. I would order returnable spacers just in case to have on hand.
  6. Dec 4, 2021 at 12:19 PM
    Hunter10mm
    2021 DCLB
    Coming
    No issues with Trac control, but my TPS is giving me fits
  7. Dec 4, 2021 at 1:16 PM
    jetso
    Jetso
    Thank you all! I feel a bit better about it now. I do plan to try the speedometer calibration to get shifting and milage, etc to be accurate. @Hunter, you are the first to mention this with this combo. Did you have aftermarket upper control arms or just the stock? What is your setup?
  8. Dec 4, 2021 at 1:35 PM
    Hunter10mm
    2021 DCLB
    Coming
    RC 3.5” Vertex Shocks (way underrated)
    RC upper Control Arms
    Heated Leather Kit
    New speakers/10” Sub
    Needed 1.25” Spacers
    Coach Builder 1/2” Shim Kit (no rub)
    Dirty Deeds 8” Exhust
    295/70r18
    Factory Ordered TRD Pro Wheels
    Downytide and biebs96 like this.
  9. Dec 4, 2021 at 1:39 PM
    jetso
    Jetso
    Nice ride! You're right, that is close to what I'm going to have :) Are those wheels +60 offset? I've got the alloy silver/black ones that come factory.
  10. Dec 4, 2021 at 1:42 PM
    Hunter10mm
    2021 DCLB
    Coming
    Thanks; I am real happy with it. I think they are +60, but there are so many little variations in these things as I discovered. It really seemed like what worked for some certain years and others not at all. I am glad I had the spacers on had as an afterthought as I needed them.
  11. Dec 4, 2021 at 3:36 PM
    jetso
    Jetso
    Good to know! Appreciate your help, I'll grab a pair in case. The 1.25in left you with plenty of threads, etc?
  12. Dec 4, 2021 at 4:47 PM
    Hunter10mm
    2021 DCLB
    Coming
    Yes. 1.25”
    jetso[OP] likes this.
