Lift+Suspension Recommendations
Discussion in 'Suspension' started by nrm91, Apr 2, 2025.
  1. Apr 2, 2025 at 3:24 PM
    nrm91
    nrm91 [OP] New Member
    Boise, ID
    2022 Platinum CrewMax Magnetic Grey
    35/11.5/20 Toyo AT III's
    Have a 2022 Platinum and with the stop sale of the factory TRD lift, I am looking at aftermarket. Wondering if anyone has some recommendations. Looking to do light off-roading (mostly forest roads, some gravel trails in ID) and hopefully eventually get a RTT. I liked the Toyota factory lift because it was reasonably affordable and seemed to be good. Now I have looked at Dobinsons, Rough Country and Icon. Wondering if I could get some recommendations (with links or actual product name so I can find it easily).
  2. Apr 2, 2025 at 3:46 PM
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    Another couple of options that you might consider would be the Bilstein 6112/6100 setup, and the Eibach suspension systems. Both are going to be high quality options, and handle the FS roads with ease. The Eibach has been the most popular 22+ Tundra suspension for us, and we anticipate the 6112/6100 to be very good as well. If you want to push the truck a little harder though, you can't go wrong with the Icons.
    Happy to help answer any other questions you may have on the topic though! You can ask away here, or can always feel free to give me a buzz over here at Hotshot Offroad.
    Bilstein 6112/6100 Info:
    https://hotshotoffroad.com/collecti...nsion-kit-2022-toyota-tundra-and-2023-sequoia
    https://hotshotoffroad.com/collecti...8-6100-rear-shock-absorber-2022-toyota-tundra
    Eibach 2R Info:
    https://hotshotoffroad.com/collecti...ducts/pro-truck-lift-kit-stage-2r-2022-tundra
    Other full kits:
    https://hotshotoffroad.com/collections/2022-tundra-full-kits
    RobertD, Blufin and Yaboy like this.
  3. Apr 2, 2025 at 4:16 PM
    Daedalus
    Daedalus New Member
  4. Apr 2, 2025 at 4:19 PM
    memario1214
    Colton
    Missoula, MT
    In terms of…? Sorry, I just maybe am not understanding your question!
    RobertD likes this.
  5. Apr 2, 2025 at 4:24 PM
    Daedalus
    Daedalus New Member
    Reviews, comparisons to others
    I had fox 2.0 on my f150 and they were great off road. A bit firm on road for me.
    I like the stock feeling of the TRD Off-road shocks. Trying to replicate that with a level.
  6. Apr 3, 2025 at 6:39 AM
    memario1214
    Colton
    Missoula, MT
    At a surface level, pretty much any performance-biased suspension setup is going to firm up the ride on the small inputs like a crack in the road. That said, the Eibach pro truck kits have almost become our go-to for the daily drivers that want to maintain as comfortable or car-like of a ride as possible while keeping on the modest side of budget. They generally run a lower spring rate than other options, and the valving is going to be a similar profile to your OEM equipment. They're likely right up your alley based on what you've shared.
    atc250r and Daedalus[QUOTED] like this.
  7. Apr 3, 2025 at 6:43 AM
    Daedalus
    Daedalus New Member
    That's the information I needed to hear. Thanks!
    memario1214[QUOTED] likes this.
  8. Apr 3, 2025 at 7:53 AM
    crikeymike
    crikeymike ExitOffroad.com
    Jacksonville Beach, FL
    Here are the 2 Dobinsons kit options, one is IMS non-resi monotube shocks, and the other is the MRR 3-way adjustable remote resi option.
    https://exitoffroad.com/product/dobinsons-2-3-ims-suspension-kit-2022-toyota-tundra/
    https://exitoffroad.com/product/dobinsons-2-3-mrr-suspension-kit-2022-toyota-tundra/
    Let me know what specific questions you have about them. If you keep the lift height low, you'll need the minimal amount of parts, keeping the cost down.
  9. Apr 4, 2025 at 10:36 AM
    nrm91
    Boise, ID
    Sent you a message
  10. Apr 4, 2025 at 6:55 PM
    blenton
    blenton New Member
    @memario1214 is spot on with his description of the Eibach kit, though I think Bilstein 5100’s are going to be closer in profile to your factory TRD shocks. I’ve run most of the shocks mentioned here in the thread except Rough Country and find Eibachs to be the softest riding but not quite as good for heavy loads and towing, Bilsteins to be the Swiss Army knife with a little stiffer ride that translate small bumps a bit more but with better handling and towing, and Icons to be the stiffest.
    Daedalus likes this.
  11. Apr 4, 2025 at 7:25 PM
    Daedalus
    Daedalus New Member
    For the moment I may not bother with the rear shocks.
    I don’t tow, nor do I have a lot of weight I tote around, so that’s an easy choice in the rears.
    realistically I’m trying to decide if I want to level the front, at the risk of losing ride quality.
    plus having to monkey with the alignment.
    We shall see how things shake out.
  12. Apr 4, 2025 at 7:36 PM
    blenton
    blenton New Member
    Gotcha. Here’s what I know about leveling the front: if you do it on the cheap, it will ruin your ride. You will lose both uptravel and downtravel, causing topping and bottoming and decreasing overall travel. If you do it right (not necessarily expensive, but an adjustable coilover like 5100’s eibachs, etc) you can improve the ride by creating more uptravel and downtravel, or at least gaining some downtravel, giving the shocks more time to dampen suspension movement.
    You will change the balance of the vehicle by leveling it, so you may want to reconsider doing the rears at the same time, just to keep it more balanced. You don’t have to, but IMO, it helps. You will shift some weight to the rear axle, so you may actually be closer to bottoming the rear.
    From what I’ve read of the 3rd gens, 2” of leveling is about the limit before you start running in to other issues, such as requiring new CV shafts and such. Perhaps someone more knowledgeable can chime in on that. I’ve always tried for keep my vehicles at around 1” of lift to maintain expected dynamics but still gain some travel.
    memario1214 likes this.
  13. Apr 4, 2025 at 7:42 PM
    Daedalus
    Daedalus New Member
    I spent the last few weeks during lunch pouring over the suspension thread. It’s been super helpful finding the limitations on stock equipment.
    I had the spacer lift for a bit on my F150. Got into coil bind.
    Swapped out to new aftermarket UCAs and Fox 2.0 and it was fine after that. Ran the 2.0 on the rear as well.
    I’ll probably end up with the eibach kit, front and rear.
    I’ve just got to find the time. I’m at a point in my life (8yr old and a 3mo old) where I have the money, but time seems to be the thing I have the least of.
    The truck may see some light off-road work, and little to no towing other than what goes in the bed.
    Comfortable ride and aesthetics are the goal here.
    Thanks for the input
    blenton[QUOTED] likes this.
  14. Apr 6, 2025 at 8:42 AM
    Sunstealer
    Sunstealer New Member
    2024 Platinum TRD HV Celestial Silver
    Can you use the Eibach to just level the front without touching the rear? I'd like to go about 1.75" higher since I do tow a utility trailer quite a bit. Would that allow 285/65/20 on an otherwise stock Platinum with OR package?
  15. Apr 7, 2025 at 7:22 AM
    memario1214
    Colton
    Missoula, MT
    Absolutely. We would just get you front/rear shocks, but don't change out the rear springs.
    Contrary to popular belief, the lift itself isn't going to garner you any ability to fit a larger tire at the limits. During compression the LCA/bumpstop interaction point is in the exact same position. You can absolutely make those tires fit. However, you're still going to have to make some room. You should be clear of the cab mount though!
