Lift recommendations
Discussion in 'Suspension' started by Ac91, Mar 22, 2018.
  1. Mar 22, 2018 at 2:37 AM
    Ac91
    Ac91 [OP] New Member
    Dallas
    2018 Tundra SR5
    Hey guys, I am completely new to lifts I’ve read through numerous threads on lifts and it just gets more and more confusing lol. My question is what lift should I go with truck is a 2018 sr5 4x4? Truck will never probably see off-road except once in a blue moon and I would like to keep towing my trailer 2500ish lbs. Really trying to do it right the first time. I would like this to last a while for me and not break or damage my truck.
  2. Mar 22, 2018 at 2:54 AM
    Ac91
    Dallas
    2018 Tundra SR5
    I would keep the stock tires for a while since they’re new. I’ve read the 18s have to have a slight rake I would be open to just lifting the front of that is a option
    SouthBoundSteve likes this.
  3. Mar 22, 2018 at 3:11 AM
    Ac91
    Dallas
    2018 Tundra SR5
    I was looking at the bilstein 6112s is adding shocks in the rear a must or can I just leave the factory rear shocks?
  4. Mar 22, 2018 at 3:41 AM
    Ac91
    Dallas
    2018 Tundra SR5
    Ok gotcha I was looking at the bilstein 6112s and 5160s in the rear and maybe shackles?
  5. Mar 22, 2018 at 7:08 AM
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    Sounds like a good choice to me.
  6. Mar 22, 2018 at 7:42 AM
    Kwikfish
    Kwikfish Get your poop in a group!
    Tri cities,WA
    16 CM SSM
    Ill sub to see what settings you run with and final lift numbers,im still hunting for the lift i want. ..just cant decide
  7. Mar 22, 2018 at 9:41 AM
    The Eibach kit is great option to consider.
  8. Mar 22, 2018 at 10:09 AM
    Ac91
    Dallas
    2018 Tundra SR5
    I definitely like the price would control arms be a must or could that wait a bit longer?
  9. Mar 22, 2018 at 10:35 AM
    Toytec Lifts
    Toytec Lifts New Member
    Denver, CO.
    UCA's are always a good option to insure proper alignment spec the first time without any issues, we have seen a lot of people get back into factory spec just fine with the factory uppers.
    Shoot me a pm anytime if you have any questions!
    Thanks!
    -David
    Black Wolf and T-Rex266 like this.
  10. Mar 22, 2018 at 10:53 AM
    :laser::mudding:
  11. Mar 22, 2018 at 11:07 AM
    PlatinumPro
    PlatinumPro New Member
    2015 PlatinumPro Crewmax
    Bilstein 6112+5100s, Rigid Lighting, Fuel 20x9 Bronze Blitz
    when I did my 6112's I used the stock platinum shocks in the rear for 6 months before I switched in 5100's which imo aren't a significant upgrade anyway. if I was just going for lift and didn't spend any time offroad at all I would likely have left the rear shocks alone.
  12. Mar 22, 2018 at 11:09 AM
    TheBeast The Beach
    get a mild lift with coilovers like Toytec, Bilstein, etc..avoid spacers and blocks :)
  13. Mar 22, 2018 at 1:24 PM
    MistrRoboto
    MistrRoboto '17 MGM SR5 TRD CrewMax
    Virginia Beach, VA
    If I was you (which I was), I would go with 6112s, assembled at the 1.9in lift setting. Keep your stock UCAs, keep your stock rear, and see how you like it. Worse case, you change out the rear later with 5100 or 5160s.
    Looks perfect with stock size tires, and rides great. Might have a slight dip in the rear depending on the trailer when towing. If so - you could use shackles in the rear to raise it a touch.
    *Edit - here is a thread I had started before I purchased anything. I don't want to shamelessly bump it, but its got some good reading in there from other members who took the same route. https://www.tundras.com/threads/ass...l-around-buy-for-the-leveler-in-us-all.18515/
  14. Mar 22, 2018 at 2:48 PM
    Ac91
    Dallas
    2018 Tundra SR5
    Good info on there my main thing at this point is i would like to keep the stock UCA’s don’t want to get too crazy truck has only 1100 miles at this point lol I think the 6112s are the way to go for what I’m looking for
    MistrRoboto[QUOTED] likes this.
  15. Mar 22, 2018 at 2:53 PM
    Ac91
    Dallas
    2018 Tundra SR5
    Any recommendations on where to get the bilstein 6112s from? Tried a google search couldn’t find just the 6112s could only find front and rear setup
  16. Mar 22, 2018 at 2:57 PM
    Thee_Oddball
    Thee_Oddball New Member
    Eric
    Chicago
    2013 Double cab 4x4 5.7L, 78,000 miles, Nautical blue.
    don't listen to the nonsense these scaredy cats are telling you...if you going to lift go big!!:thumbsup::rofl::yes:
    :D:D:p;)
    TXRailRoadBandit73 likes this.
  17. Mar 22, 2018 at 3:04 PM
    mudslinger79
    mudslinger79 New Member
    Christopher
    Williamsburg, Va
    2006 Double Cab, Phantom Grey Pearl
    Leveled. 16x8 Pacer 164 wrapped in 295-75-16 General AT2. Flowmaster exhaust. K&N Cold air intake.
    I'm actually going with the Eibach front shocks and their lift coils. Set on the second notch it's a 3 inch lift for my 06 Double Cab. I'll block the rear 1 inch and add their matching rear shocks. Can't beat the price and good reviews.
  18. Mar 22, 2018 at 3:07 PM
    Ac91
    Dallas
    2018 Tundra SR5
    I can just imagine the face on my service advisor if I was to pull up with my 1100 mile truck looking like that lol
    Thee_Oddball[QUOTED] likes this.
  19. Mar 22, 2018 at 3:08 PM
    Ac91
    Dallas
    2018 Tundra SR5
    I was definitely eyeing that kit after it was mentioned earlier in the thread pretty much narrowed my down to the eibach kit or the bilsteins
  20. Mar 22, 2018 at 3:11 PM
    Thee_Oddball
    Eric
    Chicago
    don't worry I am sure he will be running away from you screaming ..GODZILLA!!
  21. Mar 22, 2018 at 3:37 PM
    Casper3
    Casper3 New Member
    Jay
    CT/OH
    2017 Super White 5.7 SR5 TRD off road
    Boss 4x4s or Dirty deeds, can get em assembled too
    MistrRoboto likes this.
  22. Apr 27, 2018 at 2:55 PM
    Ac91
    Dallas
    2018 Tundra SR5
    Anyone in the dfw area got any places they recommend to install my lift dealer wanted $1400 to install coilovers lol
  23. Apr 27, 2018 at 2:57 PM
    Stroke250
    Stroke250 New Member
    Todd
    Idaho
    2023 Ford F-350
    If you were closer, I’d install for you. That price seems outrageous.
  24. Apr 27, 2018 at 3:02 PM
    Ac91
    Dallas
    2018 Tundra SR5
    Yeah I laughed my way out of the dealership they said $1400 to install and it would void my warranty while they have a 2018 in the showroom with a 7” lift
    Stroke250[QUOTED] likes this.
