Lift question
Discussion in 'Suspension' started by PHXTFR, Aug 9, 2025.
  1. Aug 9, 2025 at 10:57 AM
    PHXTFR
    PHXTFR [OP] New Member
    Tom
    2019 Super White Limited Tundra 4X4
    Hi -
    2019 Tundra Limited 4X4, current set up
    Front 5100's second setting
    3 Coachbuilder shims - 1 passenger, 2 driver
    Rear 5100's
    Coachbuilder +2 shackles
    Passenger side Bilstein is leaking, going to replace with the assembled 5100 with Eibach springs. Wheelers told me that the springs provide 2.5 inch lift, so shock spring seat is left at stock.
    I want to avoid the truck sitting nose high. Would this work, remove the single shim from the passenger side and go with a single shim on driver side? I am guessing the back will sit at about a 1/2 inch rake.
