Lift options for 2014 8ft 4x4?
Discussion in 'Suspension' started by Lkb1450, Nov 26, 2024.
  1. Nov 26, 2024 at 5:17 AM
    Lkb1450
    Lkb1450 [OP] New Member
    Hi everyone, thanks for the great info on this site!
    I just bought an 8' bed 4x4, been reading lots of info on here about options, seems like Eibach pro 2 is a good option, maybe Toytec as well. I'm not looking to break the bank but I'd like to get a good couple inch lift or so. Probably will keep stock tire size.
    Do people typically change out the leaf shackles and/or add a leaf in the back when lifting?
    Thanks for any info or recommendations!
  2. Nov 26, 2024 at 5:56 AM
    If you haul or tow, worth upgrading the rear leafs, or going RAS
    HulkSmurf14 likes this.
  3. Nov 26, 2024 at 6:50 AM
    Lkb1450
    Cool thanks! What is RAS, sorry not familiar. Definitely will be hauling firewood etc, towing a small camper and such.
    I'm not super into off roadibg but do love off a poorly maintained dirt road.
  4. Nov 26, 2024 at 7:11 AM
    Ghost Rider
    Ghost Rider Mods wouldn't be an issue if money wasn't.
    Ian
    Cypress, Texas
    2021 White Tundra CM SR5
    memario1214 and KNABORES like this.
  5. Nov 26, 2024 at 7:17 AM
    Lkb1450
    Great info, thanks! So that RAS, combined with coach builder shackles in the rear and some Eibach coil overs in the front could be a good 2-3" lift maybe? Can I get away with not doing UCAs and diff drops?
  6. Nov 26, 2024 at 7:20 AM
    Ghost Rider
    Ian
    Cypress, Texas
    At 3" you most likely need a new UCA, but talk to @memario1214 he's very knowledgeable in this, he's even got most of Eibach and other suspensions on sale right now and can def give you some advise as a whole on how to approach it for your best usage.
    Just beware, it's a very deep and dark rabbit hole, we spend countless gold there......
    All jokes aside, can't find a better guy that knows his shit better and offers advise that is worth its weight in gold
  7. Nov 26, 2024 at 9:29 AM
    Stock tire size with even a 2 inch lift will look small.
    texasrho83 likes this.
  8. Nov 26, 2024 at 11:16 AM
    Jhon
    Jhon New Member
    On the Oregon Trail
    2021 SR5 TRD OR
    Eibach Pro Truck Sport Shocks set to your desired lift height in the front with stock springs is a great option. I have mine set to 1.9" and the ride is great. As far as the rear goes there's a lot of options if your stock springs are not flattened. I've ran blue Sumo Springs since the truck had 1000 miles on it; they are great. I added a 1" block when I installed the front lift. Kept enough rake for towing and it handles great.
  9. Nov 27, 2024 at 5:44 AM
    Ghost Rider
    Ian
    Cypress, Texas
    That was something I was afraid of, but hoping running my OE 20 inch wheel with similar AT tires would compensate that a bit.
