Lift Kit
Discussion in 'Suspension' started by tundrabubba, Feb 28, 2023.
  1. Feb 28, 2023 at 6:22 PM
    tundrabubba
    tundrabubba [OP] New Member
    Andrew
    Hello Folks! I recently bought my first tundra about 3 months ago and had some questions on the current lift setup vs switching to a "newer lift" setup.
    The current setup on my truck is the "poor man lift" 1f603_398273c7e9ebf5d2a6dcf491921d77cdd3ef805b.png. Its just a spacer lift on the front which I think is 1.5 to 2 in. The rear is just a 1.5 (AAF) add a leaf on OEM shocks. Will there by any issues in the future that I would need to worry about? I dont do any off roading and tow on occasion my 4 wheelers.
    If I were to switch to another lift, Id probably want a 3in lift. Whats a good lift that doesn't break the bank?
  2. Mar 1, 2023 at 8:59 AM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    Howdy.
    Suspension thread secrion is linked below. Lots and lots of great info with pics and wheel tire setups too. Anything 3inch or more you need new UCA setup. Most of us go 2.5". 3inch and above you start getting into 35s and body chop to fit bigger tire setups. My setup in my sig was roughly 2k for Suspension parts and 3k for wheels and rubber.
    Good luck.
    https://www.tundras.com/forums/suspension.19/
  3. Mar 1, 2023 at 5:26 PM
    eagleguy
    eagleguy New Member
    Why do you think your lift is a "Poor Mans Lift"? It will work fine for your needs.
