Lift Kit Questions.
Discussion in 'Suspension' started by Noshoesdrew, Feb 13, 2020.
  1. Feb 13, 2020 at 1:28 PM
    Noshoesdrew
    Noshoesdrew [OP] New Member
    Drew
    06 tundra
    So I have a 2006 Tundra and want to lift it and be able to fit 35s. What size lift should I go with? It's also 2WD so I dont know if that makes a difference. I'm use to my F250s so this is new to me. TYIA
  2. Feb 13, 2020 at 1:34 PM
    Hhtundra
    Hhtundra New Member
    Most people go 2.50-3 in the front and 1-1.5 in the back, if u go with a 35 tire, most are 34 and some change in actual size, u will most likely need a body mount chop in the front. There are so many options, try and stay away from spacers, toytec has some nice packages. You will most likely need to go with an aftermarket upper control arm up front as well.
    Noshoesdrew[OP] likes this.
  3. Feb 13, 2020 at 1:36 PM
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
