Lift kit just for leveling, nothing else!
Discussion in 'Suspension' started by eagleguy, May 6, 2021.
  1. May 6, 2021 at 3:41 PM
    eagleguy
    eagleguy [OP] New Member
    I see so many recommendations for lifts for a 2021 Tundra CrewMax but have a humble question. Keeping as many OEM components in place as possible what is the easiest and best way to just bring up the front end without creating other issues?
  2. May 6, 2021 at 3:52 PM
    Sitting Sideways
    Sitting Sideways Probably stuck somewhere
    Beaverton, Oregon
    2021 White CM Tundra TRD Off Road
    Icon IR Coilovers, Icon Delta Joint tubular upper control arms, Icon PB CDC rear shocks, Icon Expansion Pack, Icon Hydraulic Bump Stops, Durobumps front bump stops, TRD dual exhaust black tips, TRD pro skid plate, TRD cold air intake system, TRD pro shift knob, TRD Pro Wheels, Falken Wildpeak AT3W tires, TRD radiator cap, ESP under seat storage, spray in bed liner, bed rail system, SDHQ abs guards, black tundra letter inserts, center console wireless charger, center console organizer/tray, charcoal filter removal, whistle screen removed, RCI Transmission/Transfer case skid plate, and ICON neoprene shock wraps
    It all depends on what you want to do. It sounds like you just want the look of a leveled truck. In that case, I would recommend just a simple spacer lift. They bolt onto your coilovers and will require an alignment.
    Hoff likes this.
  3. May 6, 2021 at 3:56 PM
    Nowhereman
    Nowhereman New Member
    Al
    Monterey Bay area
    2021 Tundra SR5 / TRD / Cement
    Rough Country shocks, ReTrax cover, Summo springs, black out badging, bed extender, "some other things I can't mention"
    I did the same but, I'm not sold on spacers for personal reasons.
    I popped for a pair of Rough Country N3s / $330 bucks.
    Did the job and I have a level truck with full suspension function.
    Alignment is required even for a two inch level lift.
  4. May 6, 2021 at 3:57 PM
    Blueknights75
    Ron
    Clayton, NC
    Billstein 5100 shocks set at mid or top setting.
    10TundraSR5 and BravoDeltaRomeo like this.
  5. May 6, 2021 at 3:57 PM
    C.I.
    C.I. Surf, off road, sleep, repeat
    Cesar Pedrin
    Cabo, Mx
    2016 5.7 4x4 Bronze Crewmax
    Mods: Ongoing... probably never ending
    IMHO, stay away from spacers as they tend to screw suspension geometry. What you want is preload from an adjustable shock such as Bilstein 5100's (these might as well be OEM)
  6. May 6, 2021 at 4:10 PM
    parkerbows
    parkerbows New Member
    Jack
    2017 crew max sr5 trd off road
    Firestone air ride air bags
    I agree bilstein 5100 or the 6112
  7. May 6, 2021 at 4:23 PM
    Tundra694
    Tundra694 New Member
    AJ
    2021 Tundra Crew Max Trd Off Road
    Bilsteins. These are 6112s at 1.9” in the front.
    captjeff likes this.
  8. May 6, 2021 at 4:24 PM
    Black
    Black Raised Hands Surround Us. 3 Nails To Protect Us
    2014 Tundra Limited CrewMax
    Falcon Leveling System, Coachbuilder +1s, RCI Skid Plates
    Falcons!!
    Ride so much better than Bilstein.
    French Avocado and GODZILLA like this.
  9. May 6, 2021 at 4:27 PM
    parkerbows
    Jack
    Just looked at prices I can see why
    BravoDeltaRomeo likes this.
  10. May 6, 2021 at 4:32 PM
    eagleguy
    So are we saying that shocks alone will do the trick? Seems like a shock that gives the extra lift to level the front to the rear would be way stiffer and totally change the ride. Am I wrong?
  11. May 6, 2021 at 4:39 PM
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    Not necessarily. The Bilstein 5100 is about the same shock as the OEM TRD shocks (Bilstein 4600), except that the perch that the coil sits on is positioned higher on the shock body than the OEM, which is where the lift comes from; not from stiffer shock or spring.
  12. May 6, 2021 at 4:41 PM
    froghill
    froghill New Member
    White 5.7 trd sport
    Fresh off the line
    Watching to see the same. Shocks alone just seems like a quick way out.
  13. May 6, 2021 at 4:43 PM
    froghill
    froghill New Member
    White 5.7 trd sport
    Fresh off the line
    cool then. I wasn’t seeing the way they work
  14. May 6, 2021 at 4:44 PM
    Black
    Yes and no.
    Bilstein 5100s ride like complete crap
    6112s are decent and include a new spring
    Falcons reuse the factory springs but incorporate a progressive bump stops and zone rate tuning giving an outstanding ride.
    The rears have piggy back reservoir.
    I have had Bilstein 5100s and Fox 2.0s personally and been in a couple with the 6112s and these Falcons absolutely blow all three of those out of the water.
  15. May 6, 2021 at 4:46 PM
    Mr_Kane
    Mr_Kane New Member
    2019 TSS Crewmax
    :Eibach 2.5" Lift :SPC UCA's :34" Toyo AT3's :10" BA Muffler
    Bilsteins are pretty hard to find right now. I went with Eibach 2.5” stage 1 shocks and coils directly from their website. Looks good to me and rides good.
  16. May 6, 2021 at 4:53 PM
    Nowhereman
    Al
    Monterey Bay area
    Guys, he just wants to level his rig, not run Baha.
    NO NEED FOR MEGA BUCK SHOCKS.
    The Rough Country units feel better than the brand new OEMs on my 2021 rig that were used for a level job.
    just sayin..
  17. May 6, 2021 at 4:54 PM
    parkerbows
    Jack
    What kind of cash we talking for those. Certainly look great
  18. May 6, 2021 at 5:01 PM
    Mr_Kane
    Mr_Kane New Member
    2019 TSS Crewmax
    The easiest way may not be best way for your truck and or ride quality. Do a search for spacer kits and many advise against it.
  19. May 6, 2021 at 5:22 PM
    Black
    Nothing suggested here will run Baja.
    You just missed the group buy saving about $300.
    But they are $1500 for the adjustable tow/haul rears and $1400 for the non adjustable rears.
    https://www.stage3motorsports.com/13-04-21-400-002-07-20-tundra-falcon-sport-2.25-leveling-kit.html
    Yes, they are on the upper end on the price spectrum but there is absolutely reason for it. The quality is top notch and the ride is fantastic.
    I wanted top quality and a great ride but providing me the ability to do moderate off-road trails but had no desire for for any lift over 2.5”
    Like I said I have had the other decent options and they do not come close to these Falcons.
    French Avocado and Mr_Kane like this.
  20. May 6, 2021 at 6:19 PM
    eagleguy
    Part numbers for the front Bilsteins or kit? Just looking to maybe level off the front with the rear. No off roading planned but maybe towing a camper, boat.
  21. May 6, 2021 at 6:38 PM
    biebs96
    PA
    BravoDeltaRomeo and 15whtrd like this.
  22. May 6, 2021 at 9:55 PM
    Nowhereman
    Al
    Monterey Bay area
    Any issues with rubbing from lock to lock?
  23. May 7, 2021 at 3:48 AM
    biebs96
    PA
    no. It’s close but no.
  24. May 7, 2021 at 6:27 AM
    parkerbows
    Jack
    spacers or no?
  25. May 7, 2021 at 7:06 AM
    1794TX
    Steven
    N.TX
    '20 1794
    With no spacers and 285's, does it bring the outer edge of the tire flush with the fender, or is it still sucked in a tad? Truck looks really great.
  26. May 7, 2021 at 7:47 AM
    vl184009
    vl184009 Cheers Boys!
    Vicky
    Southern, Ca.
    2016 MGM CM SR5 4x4 w/Tow Pkg
    THIS!
  27. May 7, 2021 at 7:50 AM
    biebs96
    PA
    no spacers are used.
    the tire is flush with the fenders just because of its overall size.
  28. May 7, 2021 at 8:52 AM
    1794TX
    Steven
    N.TX
    '20 1794
    Thanks very much.
  29. May 7, 2021 at 4:07 PM
    biebs96
    PA
    rear - looking forward
    front - looking down and towards the rear
  30. May 7, 2021 at 5:54 PM
    1794TX
    Steven
    N.TX
    '20 1794
    Very nice. Thank you. I like the not-stock, but not-too-aggressive stance having the tire walls flush, and have wanted to keep Toyota wheels (maybe 20" - haven't decided that). This goes a long way to helping me wrap my mind around the end product. Havagoodn.
    biebs96 likes this.
