Lift kit for my inverter generator
Discussion in 'Outdoors' started by rockmup, Mar 5, 2021.
  1. Mar 5, 2021 at 4:00 PM
    rockmup
    rockmup [OP] New Member
    Todd
    Greenwell Springs LA.
    Predator 3500, I've had this for 5 yrs and have 500+ hrs on it. The only complaint I've had is that its hard to move around and oil changes are a pain in the backside.
    So, 2- 3' chunks of all-thread, some foam filled wheels and a couple of hrs of my time with a couple of beers and away we go.
    I was going to make a sub frame and fit it underneath, it actually has a frame but when I flipped it up and removed the wheels it has a solid axle front and rear so ............. I removed the wheels, did a little grinding on some tabs, used zip ties to hold them in place and tacked them up. There is a 3/16 gap between the original axle and the all-thread so I used a 1" long piece of key stock to fill the gap and welded it up. I didn't bother to grind the all-thread so if you've ever welded to it you know it can get ugly.
    I will flip it and weld the backsides tomorrow. First pic is the original wheels and how I keep it fueled.
    Speaking of that, we ran this for 40+ hrs during the ice storm last month and when I turned it off it had a cracked fuel line and all the fuel drained out. 20.00 later and I have a whole new carb kit. I'm also adding a solar battery tender while I'm in there.
  2. Mar 20, 2021 at 7:21 PM
    rockmup
    Todd
    This thing has started by the second pull every time, I work out of town a lot so to make it easier for my wife I put in an AGM battery and a solar battery tender. She has 2 plates and 18 screws in each wrist so it a little difficult for her.
    This tender was cheap and came with a bunch of connections so it can be unplugged from the generator and used for something else.
    https://smile.amazon.com/gp/product/B07ZQ85PQJ/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8
    https://smile.amazon.com/gp/product/B07D7NB328/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8
  3. Mar 20, 2021 at 7:28 PM
    Melikeymy beer
    Melikeymy beer No cooler for you!
    Muscogee Nation
    2025 RAM 3500 6.7L Cummins
    Very cool gravity fill setup.
    rockmup[OP] likes this.
  4. Mar 20, 2021 at 7:33 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Looks like your current bush is all ready to rumble now. :thumbsup:
  5. Mar 21, 2021 at 7:59 AM
    rockmup
    Todd
    It'll run for >100hrs under load just like that. Which means it needs an oil change, the new tires make that a breeze.
