Lift kit for 2015 Tundra
Discussion in 'Suspension' started by Pwtaylor2113, Jun 7, 2018.
  1. Jun 7, 2018 at 4:55 PM
    Pwtaylor2113
    Pwtaylor2113 [OP] New Member
    I have a 2015 Tundra SR5 4X4 I was just given a set of Ooen Country 35 12.50-18 tires. I’m new to all this building stuff. Need advice on what size lift kit and possibly a recommendation of brand. So I can fit these band boys on my truck.
    Thanks
    Sarge
  2. Jun 7, 2018 at 5:34 PM
    That depends on what you use your truck for? How high of a lift are you wanting? Budget?
    Stroke250, Black Wolf and 4x4_Angel like this.
  3. Jun 7, 2018 at 5:41 PM
    Pwtaylor2113
    I work on the pipeline here in Northern Pa so I am doing some major off roading almost every day. It is currently stock height but I know those 35s won’t fit. Do you think a 4 inch lift would be enough if s lift to fit that size tire.
    4x4_Angel likes this.
  4. Jun 7, 2018 at 5:44 PM
    4x4_Angel
    Bree
    Funky Town, Texas
    2014 SR5 CM Silver Sky
    I have 34.5" tires on mine....i have a the ToyTec Boss leveling lift on my truck.
    Minor adjustments for rubbing
    Stroke250, jeremyd, Coolhardy and 2 others like this.
  5. Jun 7, 2018 at 5:57 PM
    Pwtaylor2113
    Nice truck looks really good. Thanks for the advice. I can’t wait to get this all done. And show the truck off.
  6. Jun 7, 2018 at 5:58 PM
    4x4_Angel
    Bree
    Funky Town, Texas
    Thanks! Very welcome!
    I called @Toytec Lifts directly (or you can message them here) and they can help you with what you are looking for if you want to go with them. I told them my budget and told them what i use my truck for. They were awesome!
    Good luck with whatever you go with! Can't wait to see what you decide.
    Stroke250 and T-Rex266 like this.
  7. Jun 7, 2018 at 6:02 PM
    Sterlinglwood
    Sterlinglwood Never enough!
    Sterling
    Newbury Park, CA
    2017 Tundra Double Cab SR5 4X4
    All depends on how light you want your wallet to be.
  8. Jun 7, 2018 at 6:13 PM
    Closer please
    4x4_Angel[QUOTED] and Black Wolf like this.
  9. Jun 7, 2018 at 6:24 PM
    Hey Sarge...Check out ToyTec's Old Man Emu suspension setup. Not just lift but totally tuned to your Tundra and it won't break the bank. Also consider getting Relentless.com Cab mount chop plates.....makes it so much easier to fit 35s depending on your rim offset. IMHO.
  10. Jun 7, 2018 at 6:40 PM
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    You can fit 35’s on a 3/1 suspension lift, I’m currently running 295/70R18’s (basically skinny 35’s) on Toytec’s Radflo setup. I only had to push the front wheel well liners forward and remove mud flaps. My advice would be to stay away from spacer lifts and drop brackets.
    trayday, Sterlinglwood and Black Wolf like this.
  11. Jun 7, 2018 at 6:55 PM
    It's one thing fitting 35s to clear the rear mount chop but make sure you have enough room to play off road...just sayin.
    trayday and Sterlinglwood like this.
  12. Jun 7, 2018 at 7:13 PM
    Stroke250
    Stroke250 New Member
    Todd
    Idaho
    2023 Ford F-350
    Another vote for @Toytec Lifts. David will get you all set up. The boss kit would probably be a great setup for you.
  13. Jun 8, 2018 at 12:06 PM
    Pwtaylor2113
    Thanks so much for all the input. You guys are the best.
  14. Jun 8, 2018 at 12:41 PM
    trayday
    trayday New Member
    Oregon
    2015 limited CM 5.7
    Fitting 35's can be done with a new set of coilovers, leveling the rear and UCA's and you will be able to get to where ever you need to be a lot quicker and more comfortable than a lift kit. If you're wanting the lift kit, I'm happy with my BDS lift. I wouldn't go any higher than a 6" lift with 35's or it'll start to look silly IMO.
