Lift kit 2 wd
Discussion in 'Suspension' started by Chadwig103, May 23, 2018.
  1. May 23, 2018 at 5:53 AM
    Chadwig103
    Chadwig103 [OP] New Member
    Chad
    2004 2wd
    So i have a 2004 2wd wanting to give a little lift on her. Found some 3 in. spacers for the front. What do you guys recommend to keep a level look for the rear blocks? Also still have stock rear shocks. Will i need new shocks in the rear???
  2. May 23, 2018 at 5:57 AM
    If you raise the rear higher than 1”, yes you’ll need after market shocks.
  3. May 23, 2018 at 6:05 AM
    Chadwig103
    Chad
    2004 2wd
    Right on that i what i was thinking.... So 3 in the front 1 in the rear and my truck will be level????
