Lift Installation and advice
Discussion in '2.5 Gen Tundras (2014-2021)' started by rustynail11, Dec 7, 2018.
  1. Dec 7, 2018 at 6:06 AM
    rustynail11
    rustynail11 [OP] New Member
    Scott
    Mansfield,TX (DFW Area)
    2017 Grey Tundra TRD
    Trying to decide the best way to level my truck. Do I go with Bilstein's on the front or go with the Toytec 3 inch lift. I am familiar with the Bilstein's but don't know much about the Toytec lifts so I have a few questions.
    How difficulty is it to install the lift? Or best shop in DFW to have this done at? (not 4WheelParts)
    What size tire can I go up to with the Toytec lift vs the Bilstein's?
    Ho bad with MPG suffer with the Toytec lift? Currently averaging 14.2 MPG
  2. Dec 7, 2018 at 6:11 AM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    With the Toytec, youll be getting a half inch more lift as the top setting on the 6112s is only 2.5 inches. That is what i am currently running and with a BMC, and standard plastic trimming i am running 35 x12.5 18s. As far as install goes, they will both take about the same amount of time. Being slightly mechanical @HornFrog and i, put his Kings on in less than 6 hours.
    HornFrog likes this.
  3. Dec 7, 2018 at 6:45 AM
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    What"s your avg mpg?
  4. Dec 7, 2018 at 6:48 AM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    I havent done a speedo recalibration so my miles are off therefore my MPGs are, as well. At best guess though i would say 11 or so.
  5. Dec 7, 2018 at 6:57 AM
    HornFrog
    HornFrog Go Frogs!
    Fort Worth
    2016 MGM SR5 4x4 Crewmax
    TC UCA's, King 2.5, Ex-Pelf Bumpers and skids, TRD Pro Grill, 2018 Lights, BD Fogs, FRAC
    At the bottom of the Discount Tire calculator is a speedometer conversion. It uses your OE tire size and compares it with your new size to give you an approximate speed conversion at different speeds.
  6. Dec 7, 2018 at 6:59 AM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    I mean i havent done one on the truck. My miles on the truck arent right in comparison. Therefore i cant calculate properly.
  7. Dec 7, 2018 at 7:01 AM
    HornFrog
    HornFrog Go Frogs!
    Fort Worth
    I know. I was just saying there a cool tool out there to play around with.
    Larmand[QUOTED] likes this.
  8. Dec 7, 2018 at 7:03 AM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    I need to find someone with a hypertech.
