Lift brand suggestions and possible trimming for 33x12.5r18?
Discussion in 'Suspension' started by crumf20, May 17, 2020.
  1. May 17, 2020 at 2:38 PM
    crumf20
    crumf20 [OP] New Member
    Wesley
    Hey guys, I have a stock suspension 2014 SR5, Looking into leveling/lifting this next week. Ive read all the threads for suspension and tires but wan a more direct answer from the experts. Don't need anything crazy and going to go spacer lift route for front, either 2.5 or 3in. Any suggestions on brands? Do I need anything in the back as well? Also going to upgrade tires. Thinking of going the 33x12.5.r18 route, will I need to trim and will it be okay with stock powder-coated rims?
  2. May 18, 2020 at 6:25 AM
    I would go with Bilstein 5100s over spacers.
  3. May 18, 2020 at 9:34 AM
    crumf20
    Wesley
    Very true, so if I did 5100’s front and back with the front on the highest setting would I be able to achieve 3in in the front?
  4. May 18, 2020 at 9:46 AM
    They will level but not as high as 3 inches. I have Toytec Alumas myself....I got them to replace the Readylift 3/2 spacer kit that I had. Ride is so much better. Depending on what you want to spend, there are many options. Spacers are obviously on the low end, and definitely not recommended if you offroad. A few members run FatBobs coilovers and are happy with them. @Toytec Lifts can answer alot of your questions as well. Here is my setup.
    Ketchumj likes this.
  5. May 18, 2020 at 9:51 AM
    crumf20
    Wesley
    Hmmm okay looking for 3in, what would you recommend? Is it possible to run the 5100’s with a small spacer too?
  6. May 18, 2020 at 10:05 AM
    crumf20
    Wesley
    How does everyone feel about the Fatbob Coilovers?
  7. May 18, 2020 at 10:10 AM
    TwistedTad
    TwistedTad TRUCK GANG “T”
    Tad
    Canyon Lake, CA
    2019 Cement Limited CM 4x4
    5100’s go up to 2.3 inches on the top setting. You can use a 1/4 shim to get you up to almost 3 inches. Fatbob’s are good. There is a pair for sale on the 3rd Gen Marketplace. $550 shipped. Not mine!!
    crumf20[OP] likes this.
  8. May 18, 2020 at 10:16 AM
    crumf20
    Wesley
    Appreciate it! I’ll take a look
  9. May 18, 2020 at 10:22 AM
    I'm so far against spacer lifts now...lol. The shackles definitely ride better than the blocks. I dont know how some disagree with that.
  10. May 18, 2020 at 12:36 PM
    TwistedTad
    Tad
    Canyon Lake, CA
  11. May 20, 2020 at 1:50 PM
    crumf20
    Wesley
    Hmmm, wish they weren't sold. Is it okay to do 5100's all around and use eibach coils instead of OEM to gain more height?
  12. May 20, 2020 at 2:12 PM
    @Toytec Lifts
  13. May 20, 2020 at 9:33 PM
    Here is my Toytec setup with 285/70/18's on a 0 offset. Right around 3.5 in the front and 2 rear.
  14. May 23, 2020 at 12:16 AM
    Part_time
    Part_time Not a new member
    Oregon
    2017 MICA BRONZE SR5
    Are there any issues with 0 offset and a lift
  15. May 23, 2020 at 6:06 AM
    Not at all. Some get a slight rub at full lock depending on tire size, but usually an easy fix. 285/70 and 295/70 is the most popular size tires with this size lift.
