Lift blocks and towing?
Discussion in '1st Gen Tundras (2000-2006)' started by cody c, Dec 15, 2023.
  1. Dec 15, 2023 at 8:43 AM
    cody c
    cody c [OP] New Member
    cody
    blue 2006 tundra double cab 4x4
    retractable fog lights, dry box mounted winch
    So what’s the deal with the suggestion to not use lift blocks if you plan on towing?
    my guess that this is due to axle hop, or different handling (braking) characteristics as opposed to heavy duty leaf spring swap.
    is there any anecdotal feedback or is this more of a perceived input?
    obviously there’s going to be a difference in handling with a 2” lift block versus a 4”
    what about airbags and blocks, where the bags are only used during towing?
    I have a set of boss airbags 2503 triple convoluted bags sitting in my garage that I’ve been thinking about using more for about 1” or so of lift than actual towing, and haven’t made up my mind if it’s a good idea or not.
    regular towing isn’t something I do, but always nice to have the capacity
  2. Dec 15, 2023 at 8:47 AM
    shifty` In South Dakota Trouble ain't hard to find
    Don't do it due to axle wrap/axle hop. This is a verified, very real problem.
    You already naturally get axle wrap when towing, which increases with age of the spring. One of the 1st gen guys on YouTube shows this very clearly on his truck, axle wrap without anything, then with a block, and with AAL, and the AAL is the only one that didn't wrap when hauling heavy. I've seen one of the Tacoma dudes on there with a good video showing the natural wrap that happens as well.
    Mind you, with a 1" block it's not going to be much different than stock, or the stock wedge on some models, but anything beyond that, I personally wouldn't do it if I was hauling anything significant (400-600lb or more).
    The Black Mamba likes this.
  3. Dec 15, 2023 at 8:48 AM
    The Black Mamba
    The Black Mamba He must increase, but I must decrease - John 3:30
    Ryan
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    shifty answers that pretty well here
    https://www.tundras.com/threads/wha...-gen-tundra-today.2558/page-1706#post-3333894
  4. Dec 15, 2023 at 9:06 AM
    cody c
    cody
    Ok, so the factory leafs are already prone to leaf twist/axle hop before chucking a block in.
    Add a leaf would be better as it can be overarched a bit to assist spring rate, thicken up the leaf pack to resist twist etc.
    maybe a wider spring perch on the axle would have been of benefit as well
  5. Dec 15, 2023 at 9:58 AM
    The OEM overload leaf basically serves that purpose, I believe?
    The downside to AAL kits is some, taking the Icon 55110 kit as an example, require you to remove the overload leaf when installing their AAL kit.
    EDIT: I'm struggling to find that 1GT video and it pisses me off, it covered the topic so well. Here's the Tacoma guy, he starts to break down your options around the 50s mark, showing pics of what to expect, and the pros/cons of each depending on your habits (he doesn't mention towing, but use your imagination):
  6. Dec 22, 2023 at 7:13 AM
    Jockey
    Jockey New Member
    Albert
    2013 Toyota Tundra Crew Max 4x4
  7. Dec 22, 2023 at 8:22 AM
    cody c
    cody
    You probably don't need to for a 2" front lift, but your CV's will be happier.
    It's just a matter of your CV's and CV boots lasting longer. Nothing you need right away but something to look at.
  8. Dec 22, 2023 at 3:02 PM
    You may want to ask on the 2nd gen forum; they’ll know better than we will over here on the 1st gen forum.
    With the 1st gen you can definitely get away with it. But you’ll likely sling some CV Axle grease.
