lift and tires
Discussion in 'Suspension' started by Brutus21, Jun 9, 2022.
  1. Jun 9, 2022 at 5:23 PM
    Brutus21
    Brutus21 [OP] New Member
    Rob
    2021 Tundra TRD off road, color Cement
    I'm looking to lift my 2021 TRD off road. Like 2.5" but i want to use add a leaf for back for towing purposes. I'd like to go a little bigger on tires and wheels but not overboard.
    Any suggestions? Also don't want to sink a lot of money in it. I did one on my 2011 Rock Warrior but it was factory lifted to start. This one has no front spacers or anything.
    Thanks for any info.
  2. Jun 10, 2022 at 6:18 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Plenty of 2-2.5 lifted coilovers out there. from 5100s or 6112, to high dollar suspensions, your choices will depend on your budget and intended use. Look over the suspension forum here, thousands of post with pics and info of lift setups.
    I would skip the add a leaf, look into RAS (active suspension.com) for the rear. Will lift the rear about an inch and is designed to help support hauling and towing loads for less sag. No harsh ride like an add a leaf. You will need a carrier bearing drop as well when you lift a Tundra rear suspension.
  3. Jun 10, 2022 at 9:25 AM
    Brutus21
    Rob
    Thanks much, I’ll check out the suspension forums.
