lift and alignment
Discussion in 'Suspension' started by hinow41, Nov 26, 2020.
  1. Nov 26, 2020 at 5:31 PM
    hinow41
    hinow41 [OP] New Member
    Rob
    Hey everyone happy thanksgiving.
    I got a dobinsons lift it a couple months ago and I haven't had time to install it. Well now I have a 3 day weekend. My plan was to install the front strut assembly, UCA and do the rear shocks my self and then have a shop install the rear leafs and do an alignment at a later date. Is it okay to drive a bit before getting a alignment done. It could take a couple days for me to get in somewhere I trust. I don't drive much maybe 10 miles a day.
  2. Nov 26, 2020 at 5:49 PM
    Me personally I would align it immediately after. Mine was way off when I did my lift. I scheduled my alignment because shops were backed up, and then timed my lift install based on that.
    FirstTruck likes this.
  3. Nov 26, 2020 at 6:11 PM
    TRD423
    TRD423 New Member
    Chattanooga
    17 SR5 TRD 4X4
    -20% tint all around and over factory -2” ToyTec leveling spacer -275 70 18 BFG KO2 -TRD duel exhaust -TRD Pro skid plate -TRD Pro grille -TRD sway bar -TRD performance air filter -vinal wrapped front bumpers -Xenon Vision led head/ fog lights and interior lights -AJT Design billet shift knob
    I have a Dobinsons set up too, the 778 springs. I had it aligned 2 times in 3 weeks. It gradually went from 26” hub to fender, to 25” (as it sits now) hub to fender. Just food for thought.
  4. Nov 26, 2020 at 6:19 PM
    TriniMan
    TriniMan New Member
    SEAN
    South Carolina
    2019 White Tundra CM TSS
    Installed remote start, throttle controller, transmission oil cooler, front and rear TRD sway bars and K&N air filter.
    You need to align the truck right after you do the lift install or you will damage the tires.
  5. Nov 27, 2020 at 10:57 AM
    hinow41
    Rob
    Could you post the alignment specs?
  6. Nov 27, 2020 at 6:39 PM
    TRD423
    TRD423 New Member
    Chattanooga
    17 SR5 TRD 4X4
    im not too sure i have them anymore, i recently moved and the wife threw a ton of stuff i had saved for the truck away..she considered it “trash”.
  7. Nov 28, 2020 at 4:22 AM
    preacher35
    preacher35 RIGHTEOUS MEMBER
    2018 MGM Platinum Crewmax 4x4
    Not only is it bad for your tires to drive before it is aligned; but it is also dangerous as your steering will be unpredictable.
  8. Dec 23, 2020 at 9:20 AM
    hinow41
    Rob
    Just an update got everything installed and just got it back from getting the alignment done. This is where everything was set at.
    I have a very slight pull to the right
  9. Dec 23, 2020 at 3:12 PM
    Well, that takes care of that. Sorry OP, members argue over anything.
    Krewcial and Squatting Pigeon like this.
