Lift alignment
Discussion in 'Suspension' started by Jebell4747, Feb 22, 2019.
  1. Feb 22, 2019 at 3:44 PM
    Jebell4747
    Jebell4747 [OP] New Member
    2018 Tundra TSS
    Can someone post proper numbers for alignment after a lift. Shop swears it’s in spec but tires are \ /. I want to use your numbers to compare with there’s Monday when they recheck it. They said camber and caster was a breeze to set and toe was the hardest. ( rough country 3.5 with uca)
  2. Feb 22, 2019 at 6:50 PM
    Jebell4747
    2018 Tundra TSS
    Maybe this will help some with the same question I had. I talked to rough country and you can’t use the “factory specs” when doing an alignment. ( my kit was the 3.5” with UCA). The new A arms change things and you must align it to their specs. If not, your tires will end up like mine \ /
  3. Feb 22, 2019 at 6:59 PM
    Mnorris1206
    08 tundra
    I have a 6" lift just had mine re aligned on stock uca. Wish I had got a sheet that showes but the guy that did it said their where no hole numbers and the highest was a .10. So I took what he said as a good thing my truck rides straight just hope its all good don't like getting bad tires out of a bad alignment.
    Jebell4747[OP] likes this.
  4. Feb 22, 2019 at 7:19 PM
    Jebell4747
    2018 Tundra TSS
    According to them, the kits they sell that use new UCA’s need those numbers. Anything using factory arms can use factory settings. We’ll see Monday if it corrects my problem
    Mnorris1206 likes this.
  5. Feb 22, 2019 at 7:22 PM
    Mnorris1206
    08 tundra
    I really want after market uca but don't really want to spend the extra right now for the ones a 6" lift calls for .Some in the upper 700 dollars a little out of my budget for now .Well wish you luck I'm sure they will get it right. Or take it to another shop amd see what they say .
  6. Feb 22, 2019 at 8:35 PM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    SPC adjustables $480 on Amazon
    Mnorris1206[QUOTED] likes this.
  7. Feb 25, 2019 at 7:41 AM
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    This is mine with a 3/2.
  8. Feb 25, 2019 at 5:23 PM
    Jebell4747
    2018 Tundra TSS
    That’s the new one. It’s not in rough country specs but they said it’s right now but tires are still \ /. I guess I’ll look for another shop. This is twice I’ve told them it has to be set to rough country specs and not factory
  9. Feb 25, 2019 at 6:03 PM
    Jebell4747
    2018 Tundra TSS
    Are your tires straight? Mine are still \ /
  10. Feb 25, 2019 at 6:15 PM
    r1-superstar
    DB
    UTAH
    Mine are straight.
  11. Feb 26, 2019 at 2:29 PM
    Jebell4747
    2018 Tundra TSS
    Well I was just told by the shop all my adjustments are maxed out for camber and there’s nothing they can do. I called rough country and they wanted me to measure the center of wheel to the bottom of the fender. 25-1/8”. They said that was dead on for the 3.5” lift and there’s no way the adjustments could be maxed out. Looks pretty maxed to me. Ideas? Adjustable uppers??
  12. Apr 2, 2021 at 7:47 PM
    Calvary_Blue~Baby!
    Calvary_Blue~Baby! New Member
    2021 Calvary Blue Tundra TRD Sport
    Rough Country 3.5 lift, front coilovers, V2 rear shocks. Fuel Siege wheels 20x9 1 offset. Atturo Blade XT 33x12.5 tires. Go Rhino RB20 running boards.
    Hey Jebell,
    Did you ever get your alignment straightened out? I just got the same rough country setup and two alignment shops have not been able to get me straight. My truck is tracking pretty straight but the front wheels are pigeon toed inward \__/. I gave both shops the rough country alignment specs print out, but no luck yet any help would be greatly appreciated. Thanks bro
  13. Apr 2, 2021 at 8:23 PM
    Aught16TSS
    Aught16TSS New Member
    J
    Tuckasee
    2016 TSS - Magnetic Gray Metallic
    Dual Flowmasters, hidden LEDs in hood bulge, 3.5" lift and Ridge Graps
    I installed the 3.5” struts with UCAs from rough country yesterday. Got an alignment today. My shop went with factory specs which are within rough country specs, except for toe and total toe. My guy said he had zero problems and the alignment went smoothly. Truck tracks straight and wheels are straight.
  14. Apr 3, 2021 at 2:41 PM
    Calvary_Blue~Baby!
    Aught, thanks for the info. I'm going to take ur specs to my appointment tomorrow. Don't know if u can see the angle of wheels in this shot the steering wheel is straight.
  15. Apr 3, 2021 at 3:18 PM
    biebs96
    PA
    My tires were like yours. Took it to a dedicated alignment shop that was able to max out the camber and set it to 0.02 on each side.
    The ride changed and the early signs of feathering on the outer edges have gone away.
  16. Apr 4, 2021 at 6:08 AM
    Aught16TSS
    J
    Tuckasee
    Good luck. I checked my cams on my LCAs and they are not maxed out. Truck rides better than it did before the lift. I’ll post up some truck pics after I get my tires tomorrow or the next day. Riding around looking like a goober on skateboard wheels right now.
  17. Apr 22, 2021 at 10:44 AM
    Calvary_Blue~Baby!
    Alright, it was long road. 3 shops about 7 attempts, one replaced tierod end, and a months time, but all good now. Thank God.
    Thanks for the replies. I gave Aught16TSS specs to the shop.
    osu1978 and tbutler like this.
  18. Apr 5, 2025 at 8:03 PM
    FREEK
    FREEK New Member
    Darren
    Olathe, KS
    2019 Tundra Limited Crewmax 4X4
    How would those numbers work for a ‘19 Limited Crewmax 4x4 with a 3.5” complete lift?
