Lift - Airbag recommendations
Discussion in 'Suspension' started by DeePow208, Jun 11, 2019.
  1. Jun 11, 2019 at 8:29 PM
    DeePow208
    DeePow208 [OP] New Member
    Tundra Platinum
    howdy all,
    I just scored a 2013 Tundra Platinum with 20,000 miles. I am hoping to get a 3” lift and airbags installed over the summer. Both are essential because I spend a lot of time on dirt / rock roads and have already experienced issues coming close to rubbing.
    Airbag will be needed as I am currently searching to find a slide in pop-up camper to share with my father-in-law.
    What are your recommendations? Thanks!
    OR18TRD and Bigboitundra like this.
  2. Jun 11, 2019 at 8:30 PM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    :wave: Hiya and welcome from SoCal!!!
  3. Jun 11, 2019 at 8:48 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Toytech lifts seems to get good reviews but there are a ton of options, king, icon, OME, fox, bilstein....greatly depends on your use and budget.
    As for airbags I have had Firestone and liked them a lot. You said you go offroad so you will definitely want and need to get airbag cradles. Daystar made the ones I had and they were good. This is very important so the bags don't limit downtravel or break as a result of downtravel
    You do NOT want to use the airbags to achieve the lift for the rear of the truck. They should be used for load leveling only. So if you want to do a lift, then lift the front and rear with coilovers in front and either shackles or leaf springs in the rear. Then get bags and cradles to use when you have a payload that causes squatting.
    When you put the bags on make sure you run the air lines independently, do not run a T fitting to make them both fill from one air valve. Running them connected to each other can allow air to shift from side to side and you don't want that when you are cornering with your camper in there.
    I never felt the need to have an on board compressor or really any compressor at all. I used a standard bicycle air pump and it was cheap and effective. About 10 pumps per bag would add 5-10psi per bag and raise my back end an inch.
    There are several member that know a lot more than me about lifts and bags. I hope they chime in.
    Post up a budget and idea of what kind of lift you want and off roading you do
    SeanO86 and Pinay like this.
  4. Jun 11, 2019 at 9:45 PM
    DeePow208
    Tundra Platinum
    Thanks for prompting me with more ideas. Trying to keep the price for the lift around $3,000 with install. I will probably wait for airbags until next spring.
    The dealership stated they could install the ToyTec Boss for $2,500. I am going to be reaching out to other specialists this week. I am new to this so I don’t know basic info. If anyone can give me basic questions to ask, it would be greatly appreciated.
    I am not doing anything too intense but live in Idaho. I hunt and backpack in fairly rugged terrain and getting to the locations typically requires driving over rocks and smaller obstacles.
  5. Jun 11, 2019 at 9:56 PM
    Troynjade
    Troynjade Beast mode 5.7
    Troy
    Wa
    2008 Toyota Tundra
    7" procomp lift, 3" body lift. Amp research powerstep, 22" fuel rims, 38" nitto tires, Custom leather seat covers black with red stiching, alpine inz928 deck, 2x10" subs, 1500 watt alpine amp, 400watt amp for door speakers. Procomp Traction bars, fuel grille, Black headlight housing with 6000k hid, rear airbags, rear and front camera, k&n air intake, 40" light bar. Rear under bumper led light bar. Prodigy trailer brakes. 5.29 Nitro Gears. Auburn Posi Rear End. Dirty Deeds Budget Dump.
    I have firestone airbags. Probably alot of others to chose from but, When I tow my 29ft travel trailer it levels right out. No issues
  6. Jun 12, 2019 at 4:13 AM
    Welcome from NY.
  7. Jun 12, 2019 at 4:55 AM
    monaco730
    monaco730 New Member
    16 Inferno Tundra
    Fox shocks, TRD Exhaust, TRD grill, TRD shift knob, weathertech floor/bed liners, ARE topper, FrontRunnerOutfitters cargo rack, Relentless cargo bars, color matched front bumper/side mirrors, fuel wheels, nitto RGs, K&N intake
    Fox and Firestone
  8. Jun 12, 2019 at 5:27 AM
    Firestone.
