LF: Toyota 75720-0C010 Moulding Assy, Front Door Belt, LH
Discussion in '1st Gen Tundras (2000-2006)' started by LargeSack, Feb 14, 2023.
  1. Feb 14, 2023 at 12:48 AM
    LargeSack
    LargeSack [OP] New Member
    2006 Toyota Tundra SR5
    I have been searching all over the net for: Toyota 75720-0C010
    the cheapest price has been around 134+shipping/tax which comes out to 164ish.
    I am driving a 2006 Toyota Tundra sr5 dual cab. I can’t seem to find anything cheaper than that, has anyone else had any luck finding the same part cheaper?
  2. Feb 14, 2023 at 2:30 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Isnt this that black strip underneath the windows?
  3. Feb 14, 2023 at 2:33 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
  4. Feb 14, 2023 at 5:36 AM
    shifty` All my rowdy friends have settled down
    $135, no tax unless you live in Alabama, free ship w/code FREESHIP: https://parts.serratoyota.com/p/63250868/75720-0C010.html
    (This is the Birmingham AL Serra dealership, not the Decatur Serra, where that asshole Eric F who can't get his shit straight or own up to mistakes works)
    FirstGenVol, JasonC. and w666 like this.
  5. Feb 14, 2023 at 8:25 AM
    Norcalyotaman
    Norcalyotaman New Member
    2005 Tundra Double Cab SR5
    That’s about what I paid. Those damn things are expensive!
  6. Feb 14, 2023 at 8:29 AM
    Is it just the 'squeegee' thingy that sits at top of the door, to wipe the window as it slides across?
  7. Feb 14, 2023 at 8:54 AM
    Norcalyotaman
    Yup that’s the one
  8. Feb 14, 2023 at 10:05 AM
    Huh. @Norcalyotaman or anyone else who's replaced theirs, how much did it stop the window-rattles-when-barely-open issue many of us struggle with?
  9. Feb 14, 2023 at 10:06 AM
    LargeSack
    Yeah, it is the black strip under the driver aide window. That has been the lowest price I have been able to find as well. Thanks for your guys help.
  10. Feb 14, 2023 at 10:15 AM
    LargeSack
    Thank you for this information, I can’t believe how much these things are for 1st Gen toyota Tundra’s.
  11. Feb 14, 2023 at 10:55 AM
    Norcalyotaman
    I don’t think the belt strip has anything to do with the rattle. (It didn’t on mine at least) There are a write ups if you search but basically you have to open up the door and tighten the bolts that hold the window/track mechanism. Mine were completely loose and the rattle stopped afterwards. Also a good time to lube up the track especially if the window is slow going up and down.
  12. Feb 14, 2023 at 11:45 AM
    Someone on here replaced that strip and said it helped significantly.
    While I was swapping out my door speakers, I checked my bolts ... all tight. PHM re-drilled his track to hold the window tighter and it worked for him. Someone else installed foam backer rod in the U-shaped seal that goes around the upper rim of the door and that stopped it. Anyway, I'd never drill my doors, but clearly seals wearing down is a likely cause of the rattle. It's the reason my rear power slider rattles when half-open. It's also why the wing windows in access cab trucks let in so much road noise...
    Wish I could remember who it was having great luck with that wiper seal you guys got...
