Lexus HID bulbs....holy smokes...
Discussion in 'Off-Topic Discussion' started by ColoradoTJ, Feb 2, 2017.
  1. Feb 2, 2017 at 12:45 PM
    ColoradoTJ [OP] Certified tow LEO Staff Member
    I noticed this morning that my daily driver IS350 wasn't putting out the light it normally does. Sure enough, one bulb is out.
    Go to the local parts store, and they give me the wrong bulbs (at this point, I didn't know they were HID's). I came home and tore my front end apart and found out they were HID's. Went back to the parts store, 175.00 each. I couldn't believe it. Out of habit, I call the Lexus Dealership (sometimes...they are actually cheaper) and got a 227.00 each cost. I just laughed, and at this point might tape a LED flashlight up front.
    I did a little research, and couldn't believe where I purchased them from at a really good price.
    Home Depot online. 48.00+tax.
    I read a bunch of reviews, and these are Philips original bulbs and customers have really had good luck with them.
    I just do not see 227.00 each with these bulbs, and Lexus wanted 407.00 to install them. Wow...
  2. Feb 2, 2017 at 12:56 PM
    louscrw
    louscrw all jacked up on Mt. Dew
    Lou
    Warner Robins, Ga
    2023 F150 Raptor
    Good find at Home Depot. Yeah, I'm praying they don't ever go out on mine...they're LEDs though, so hopefully I'm good....
    and if one is out when I get home tonight, I'll be cursing that I ever posted this :censored:
  3. Feb 2, 2017 at 12:59 PM
    Theyfzman
    Theyfzman New Member
    Pa
    08 TRD
    I own a body shop and some of the prices of replacement parts is just crazy, I was at a Paint class and was talking w a tech from an Audi stealership, and one of the new Audis that is running the LED headlights the cost of the headlight assy is real close to $5000 a piece, god forbid your rear end someone in that a pair of headlights, bumper cover,grille and maybe a hood you be like $20,000 just in parts no labor or paint work........ that's just insane
  4. Feb 2, 2017 at 1:04 PM
    louscrw
    Lou
    Warner Robins, Ga
    2023 F150 Raptor
    That's nutz!!
    ColoradoTJ[OP] likes this.
  5. Feb 2, 2017 at 6:31 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    They figured if you drive a Lexus, you can afford it, which is probably why they're so high.
    SCORP_IAN and ColoradoTJ[OP] like this.
  6. Feb 2, 2017 at 6:48 PM
    For sure, baller status....buahhhaahh
    TXMiamiFan[QUOTED] likes this.
  7. Feb 2, 2017 at 7:08 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    I sure hope that includes vaseline and the courtesy of a "reach around."
  8. Feb 2, 2017 at 7:11 PM
    MotoTundra
    MotoTundra The Ocho
    Don
  9. Feb 2, 2017 at 7:13 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    What part of PA do you ride that 4wheeled dirt scooter in?
  10. Feb 2, 2017 at 7:21 PM
    eledobleu
    eledobleu retrofitwholesale.com
    Orlando, FL
    Koito Bi-LED Retrofit
    Dealer prices are always ridiculously high! Not sure about authenticity of the Home Depot Bulbs though. Theres a huge difference in output between real OEM bulbs and fake. Chances are you will see much less performance from those than the OEM bulbs that came with your car. Morimoto bulbs would probably be as bright as your OEM bulbs.
    Most companies have fake reviews on their products especially Amazon and Ebay. When you get the new bulbs (if you decide to keep them), put one OEM bulb in and one of the Home depot bulbs in and compare the brightness. You will know for sure then.
    Also, it might not actually be your bulb that went out. Could be your OEM Ballast that actually went out. I believe those are located inside the headlights on your model. Don't know if you have warranty but if so that part should be covered under Manufactures warranty.
    Also, Lexus uses Koito Bulbs and Matsushita Ballasts for their vehicles. .
  11. Feb 2, 2017 at 7:23 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas ⛽️
    Rafael
    2017 TRD PRO
    That is robbery :quickdraw:
  12. Feb 2, 2017 at 8:16 PM
    MotoTundra[QUOTED] likes this.
  13. Feb 2, 2017 at 8:20 PM
    Thanks for the heads up. It's the bulb. I switched sides and verified.
    I did read some more into the HD reviews and went on some Lexus sites. Looks like they are the OEM Philips bulbs.
    I'll keep you posted on what happens with the new bulb.
  14. Feb 2, 2017 at 8:34 PM
    J4RR3N4
    J4RR3N4 New Member
    South east Texas
    14 Tundra
    3” lift on 35’s
    Be sure to lube up them bulbs before you slide them in.
  15. Feb 3, 2017 at 5:38 AM
    Theyfzman
    Pa
    08 TRD
    Im about 25 mins north of pittsburgh Pa
    And I don't do much leasure riding
    I race harescrambles
    MotoTundra likes this.
  16. Feb 3, 2017 at 5:42 AM
    MotoTundra
    MotoTundra The Ocho
    Don
    Nice. I started racing Hare Scrambles when I was 10 in District 6 on the other side of the state. Moved to Motocross two years later. I am actually planning to do a H.S. next year. I need more seat time though, 2 hrs will smoke me!
  17. Feb 3, 2017 at 6:02 AM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    I had a ballast on one of my Lexus' go out 6 months before it got totaled. I thought it was the bulb but after taking it to the mechanics he confirmed it was the ballast. I wonder if Lexus has some type of problem with their ballasts. Not the only one this has happened to.
  18. Feb 4, 2017 at 11:39 AM
    Cost on Ballast?
  19. Feb 4, 2017 at 6:57 PM
    040Tundra
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    About $600 for the part and install. That wasn't a Lexus dealership either, but was a Lexus branded ballast.....
  20. Feb 4, 2017 at 6:58 PM
    Thanks. I will be pissed if that is the issue. If it is, some retrofit lights will be going in.
    NewImprovedRon likes this.
  21. Feb 4, 2017 at 7:04 PM
    the_midwesterner
    the_midwesterner New Member
    Luis
    None, yet....
    @ColoradoTJ pm me if you want a Toyota set. I can get you a deal.
  22. Feb 4, 2017 at 7:07 PM
    Ballasts?
  23. Feb 4, 2017 at 8:52 PM
    the_midwesterner
    Luis
    None, yet....
    Sure.
  24. Feb 4, 2017 at 8:56 PM
    I will know by the 9th. Thank you so much.
  25. Feb 5, 2017 at 12:09 AM
    aperezsh
    aperezsh Blessed are the peacemakers
    Ali
    cal-exit landed in GA
    16 Tundra SR5 4x4 Crew Max Magnetic Gray Metallic
    A little this and that...Broke now
    Yup except I'm the Wal Mart version..ballin on a budget
  26. Feb 9, 2017 at 8:58 AM
    I installed the one replacement HID bulb today.
    So, time will tell, but I'm pretty happy on that 50.00 fix vs the alternative. Packaging came in Phillips OEM box.
  27. Feb 10, 2017 at 1:32 PM
    Theyfzman
    Pa
    08 TRD
    Kinda off track a bit I did an oil change this week on a 2015 Ferrari California, Guy took it to a dealer they wanted, get this $1100 for an oil/filter change, I told him I can do it for $650 he was tickled
    12 quarts of syn. oil and a filter that looks like your basic fram filter except its black and has the Ferrari symbol on it, had to special order it of course $78 for it and $125 for the oil
    18 bolts to remove the belly pan,So how does the dealer equate $1100 for that RIIIIIIIIIIP off !
    ColoradoTJ[OP] and iHacker like this.
  28. Feb 10, 2017 at 1:36 PM
    TXMiamiFan
    Jose
    If you can afford a Ferrari, you can afford $1100 for an oil change is what they figured.
    iHacker likes this.
  29. Feb 10, 2017 at 2:06 PM
    Theyfzman
    Pa
    08 TRD
    I know that's what I told him !!! he reluctantly agreed
  30. Feb 10, 2017 at 6:18 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    I'm currently looking at is250's.... I may be picking up a commuter car but AWD is a must. No Toyota's fit the bill as I'm not a fan of the Matrix AWD. I want to go with a car, not an SUV. I prefer to stay in the Toyota family.
    It will have to be like an 07ish with some miles.
    Looking forward to another project haha.
