Lexus credit card key works in 2020 Tundra
Discussion in '2.5 Gen Tundras (2014-2021)' started by pnw.tundra, Jul 5, 2020.
  1. Jul 5, 2020 at 9:44 PM
    pnw.tundra
    pnw.tundra [OP] PNW Tundra
    Paul
    PDX
    2022 TRD Pro | Prev 2020 Tundra aka Blue Whale
    TLDR: the Lexus credit card key works and CAN be programmed for your smart key equipped Tundra. I got mine to work on my 2020.
    There are several write-ups on other Toyota forums such as the following:
    Tacomas - https://www.tacomaworld.com/threads/lexus-credit-card-key-working-in-tacoma.445979/
    Highlanders - https://www.toyotanation.com/thread...highlander.1114266/#/topics/1114266?_k=csobay
    Parts list (from the Tacoma thread; not confirmed for Tundra, but my key works):
    -Key part number: 89904-53511 or 89904-53512
    -Make sure Key says Denso model 14CBB or FCC HYQ14CBB
    -Works in through 2020 with smartkey.
    -Buy an extra Battery, CR2412
    -Emergency Key (slide in mechanical key) part number: 69515-30350
    Abbreviated process:
    1) Using Techstream connect to vehicle as Lexus LX570 3UR-FE
    2) Open up immobilizer/Smart Key ECU
    3) New key can be added via Smart Key registration following the wizard. Note that if you'r using a previously assigned key, you'll have to reseed key via a locksmith or DIY via a 3rd party website like weboctopus.nl. This process is a bit more complicated, so I'll save that for a dedicated post below.
    4) Follow-prompts until registration shows complete.
    5) Done!
    Short video of my programmed key in action - https://www.youtube.com/watch?v=J-9YFKbKQEc&feature=youtu.be
    No more carrying a set of keys/keyfob. I just keep this in my wallet, so I'll never forget my wallet and/or keys anymore.
  2. Jul 5, 2020 at 9:45 PM
    pnw.tundra
    Paul
    PDX
    Saved for used key seeding/programming write-up details.
  3. Jul 6, 2020 at 6:36 AM
    overland_sc
    overland_sc New Member
    Andrew
    2016 1794 XP CrewMax - MGM
    This is awesome! Totally going to attempt this. Hate the pocket bulge from the key fob.
    pnw.tundra[OP] likes this.
  4. Jul 6, 2020 at 8:27 AM
    pnw.tundra
    Paul
    PDX
    You’re gonna appreciate it!
  5. Jul 6, 2020 at 10:05 AM
    Gene5253
    Gene5253 New Member
    Gene
    Boise ID
    2020 Tundra CM Limited
    Sure the bulge is from the key fob??
  6. Jul 6, 2020 at 12:14 PM
    Kung
    KG, VA
    Pgain88, panicman, TokerJoker and 2 others like this.
  7. Jul 6, 2020 at 3:25 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Do you lose the use of one of your key fobs if you do this? I think Toyota has a limit of two keys programmed for a vehicle.
  8. Jul 6, 2020 at 3:26 PM
    pnw.tundra
    Paul
    PDX
    No, you can program up to 5 fobs.
  9. Jul 7, 2020 at 12:41 PM
    Anthony605
    Anthony605 New Member
    Anthony
    2020 Limited Double Cab
    I have a full function scanner that may be able to program the key to my 2020 Tundra. I have a question about the model of the credit card key. Are the part numbers you gave mandatory or does the credit card key just have to say "Denso model 14CBB or FCC HYQ14CBB"?
  10. Jul 7, 2020 at 12:48 PM
    pnw.tundra
    Paul
    PDX
    Honestly, I’m not sure. Those part numbers were from the Tacoma world thread. My key has both of those listed, but I couldn’t tell you if other models or frequencies will work or not.
  11. Jul 7, 2020 at 1:56 PM
    Anthony605
    Anthony
    OK cool. I am looking forward to hearing from people who were able to erase a fob before it is programmed. I am going to double check my scanner to make sure it has the key programming function. I am pretty sure it does.
  12. Jul 7, 2020 at 2:15 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Any of you guys with a programmer in the Southeast? Preferably the Gulf Coast of Alabama, Florida, or Mississippi?
  13. Jul 7, 2020 at 2:18 PM
    pnw.tundra
    Paul
    PDX
    I erased my 2 fobs using the smart code erase option. It took 16 mins for the process to complete in Techstream. The programming of the 3 keys was fast and simple afterwards.
  14. Jul 7, 2020 at 2:32 PM
    TundraPHX
    TundraPHX Ryan started the fire.
    Jared
    Look at all you fancies. Smug as a bedbug with your push button start. /s
  15. Jul 7, 2020 at 3:00 PM
    Anthony605
    Anthony
    I am in New Jersey....
  16. Dec 18, 2020 at 1:36 PM
    Terndrerrr
    Terndrerrr 925000 miles to go
    Music City
    6UR-FE
    Bookmarked! Thanks, OP! I just might have to try this after Christmas.
  17. Dec 18, 2020 at 2:23 PM
    Baja Fundra
    Baja Fundra New Member
    2020 Quicksand Tundra TRD Offroad
    saved for future use, I read about this on tacomaworld when I had my Tacoma, didnt think it would work on the Tundra
  18. Jul 17, 2023 at 6:57 AM
    Ipaddick
    Ipaddick New Member
    Canada
    Platinum hybrid w/advanced package
    Anyone do this for third gen? Would love to have a key in my wallet.
  19. Oct 6, 2023 at 9:28 AM
    snp
    snp New Member
    Tried two different PN for credit card keys on 3rd gen no luck
  20. Jul 12, 2024 at 6:42 PM
    pman9003
    pman9003 New Member
    2020 Platinum 4x4
    Old thread, but just adding some info for anyone considering this. I just did this to my 2020 Platinum.
    I ordered PN 89904-53512 from a Lexus dealer online and programmed it to the truck myself in under 10 mins. I used a cracked copy of Techstream (V18.00.08) and a crappy Mini-VCI USB cable I got from Amazon a few years ago.
    Couple pointers:
    1) I connected to my truck as a 2020 Tundra, just had to select the "Radar Cruise" and "Smart Key" drop downs. No need to connect to it as an LX570
    2) Connect to the Smart Key ECU in Techstream from the "All ECUs" Tab.
    3) Go to "Utility" section once you are in the "Smart Key ECU" screen.
    4) For some reason in V18.00.08 its called "Smart Code Registration". In previous versions I believe it was "Key"
    5) Make sure NOT to choose the "Classic" registration, this is a more complicated way to complete the process. The one that simply says "Smart Code Registration" is a simpler process that prompts you for each step.
    6) Follow the prompts on the screen and your new key will be working in a few easy steps. Just make sure to read all the instructions on screen completely before starting.
    Also you can actually program a total of 7 keys to the truck. The counter showing 5 in Techstream is the number of open slots (5 open + 2 Factory programmed=7). When ordering my key, the dealer insisted on having a VIN prior to shipping it. Two minutes on Autotrader and I had a VIN from an LX570 to give them.
    If anyone is having trouble finding the CR2412 batteries used in the credit card key, Digikey or Mouser are a good source. Amazon is riddled with fake batteries and the only local place I found that had them was the Lexus dealership (at $15 each).
    Nova1967 likes this.
  21. Jul 30, 2024 at 11:01 PM
    Nova1967
    Nova1967 New Member
    Maryland
    2021 tundra crew max, 1794, Smoked Mesquite
    Rear Sway bar, TRD dual exhaust, storage unit under rear seat, cargo mate, 10 spoke aftermarket 21" rims (Lexus), weather tech mates, Morimoto headlights, HR hood bar light, Chrome deleted: bulge, grille surround, valance, bumper end caps, mirrors. Replaced all parts with smoked mesquite, and L.E.D bright interior lights.
    Excellent information for Toyota owner to share such privilege knowledge. Just don't understand why Lexus and Toyota will not share this simple technology between the companies. As you my know, majority of Lexus cars today utilize regular unleaded gasoline and only a few of their high-end autos burn premium. Why buy a Lexus when Toyota cars use the same engines, cheaper gasoline and cost less for similar vehicles. Yes, the interior is much epic, massive, and stately with lots of sound deadening insulation over the daily Toyota diver. I am utilizing the LX570 10 spoke rims on my tundra which give the vehicle show room quality. At most Toyota dealerships, if you order parts for your Lexus they will not guarantee your parts nor a refund.
  22. Jul 31, 2024 at 1:09 PM
    JohnWhicker
    JohnWhicker New Member
    I need to do this. Always fun to start new projects. Any good source for a cheap key :)
  23. Jul 31, 2024 at 1:14 PM
    JohnWhicker
    You erased them 2 fobs by mistake or they were not from your current truck?
