Leveling my CM
Discussion in 'Suspension' started by Ol' Salty Dawg, Sep 25, 2019.
  1. Sep 25, 2019 at 4:45 PM
    Ol' Salty Dawg
    Ol' Salty Dawg [OP] New Member
    2017 Tundra 2WD XSP-X
    2017 cm 2WD. All I want to do is level it. Has 285/55/20's and they will stay on. Are 5100's the way to go?? Will I need an alignment after install?? Thanks
  2. Sep 25, 2019 at 5:46 PM
    I believe the 5100s will work for you. There are many posts on it. Yes you will need an alignment right after install.
  3. Sep 25, 2019 at 5:50 PM
    duece292
    duece292 Appalachian American
    Greg
    Green Bay, WI
    5100's will give you the most bang for your buck. They should improve your handling a bit and they're really not that much more than some of the better spacer lifts. Any way you go at it, coilovers or spacers, you'll definitely want to have an alignment done. I have 5100's on the middle setting and I'm very happy with them. If I did more off roading I would likely go to 6112's or a Toytec setup but the majority of my driving is on road and the 5100's are more than sufficient for me.
