Leveling Lift Plans and Advice.....
Discussion in 'Suspension' started by Safar85, Apr 7, 2021.
  1. Apr 7, 2021 at 6:46 AM
    Safar85
    Safar85 [OP] New Member
    Ed
    Corona, Ca
    2021 SR5 CM
    More than a few.....
    I recently came up on a good deal for a set of almost new TRD Sport shocks and some other suspension goodies. I have been thinking about a slight lift to the truck. I wanted to see if anyone is running the setup I was planning to do, if they have pictures, or if i should go a different way. I am pretty set on using the TRD sport shocks, but am open to suggestions on the other components.
    So this is what i have so far.
    1) TRD Sport 2 rear shocks and 2 front struts with coils. Less than 2000 miles driven from a 21 CM.
    2) 1 set of 1" coachbuilder front shims.
    3) 1 set of 1" Rear shackles.
    Does anyone have this setup? Should i consider the rough country 1.75" front spacer? Should i not worry about the shackles?
    I read that the shackles actually would give around half an inch of actual lift, and the 1" shims may give slightly more than an inch. Is this accurate? I am really just looking for a level with a slight rake and a tiny bit of lift, inch or 2 at the most. Any help would be appreciated.
