Leveling kit ?
Discussion in 'Suspension' started by Javy, Feb 27, 2014.
  1. Feb 27, 2014 at 4:22 PM
    Javy
    Javy [OP] New Member
    2012 Toyota Tundra Texas Edition 4X4
    Nothing yet ?
    I want to do a 3 in, in the front and a 1in . In the back . What are your opinions , and does anyone know if this voids suspension warranty on truck
  2. Feb 27, 2014 at 4:44 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    The term leveling kit is typically used for a front coil spacer only that brings the front up 1.5" -2" to be level with the stock rear suspension.
    3/1 is a lift kit. Semantics I know.
    To answer your warranty question, yes it will typically void warranty if it is over a certain height that I think is the 2" leveling kit. The loss of warranty can filter down to other things as well even if unrelated. Depends on the day, mood of the person and what's wrong.
    Your best lift options are suspension lifts, not spacers. Call up toytec and have them direct you to the lift kit that fits your needs.
  3. Feb 27, 2014 at 7:05 PM
    What he said ^^
    Once u change the suspension u are under a new manufacturer warranty presuming u purchase it new....although, I think it's pretty rare does someone have issues with their suspension if installed correctly
  4. Feb 28, 2014 at 1:37 PM
    Javy
    Nothing yet ?
    Thanks for y'all's input
  5. Feb 28, 2014 at 7:15 PM
    csuviper
    Broomfield, CO
    OME or Bilstein ultimate kits are your best choices for 3"
  6. Feb 28, 2014 at 8:09 PM
    imowlawns
    imowlawns New Member
    Just installed a rancho quick lift preloaded struts. 2.5 inches almost completely levels it . Leaves enough room so if you tow it doesn't look dumb. 200 a side for the preloaded struts love them nice ride too
  7. Feb 28, 2014 at 8:10 PM
    imowlawns
    yzu2ages_5f9eedaa9ede16ac63b73625ce154206fa647a22.jpg here it is
  8. Feb 28, 2014 at 8:47 PM
    Nice...now time for some bigger tires :)
  9. Feb 28, 2014 at 9:08 PM
    imowlawns
    Those are 275 / 60 r20 not much more room under there
  10. Apr 30, 2014 at 3:14 PM
    TT-Truckin
    TT-Truckin Toyota Tundra Truckin'
    Al
    Washington State
    2007 Silver DC 4.7 TRD SR5
    Tonneau bed cover
    I've been wanting to level my Tundra for years. From what I'm reading it's best to use a suspension kit and it will level out. I have the TRD package on my 07, and the ride is fairly stiff and it does smooth out with weight in the bed or towing my RV, I'm getting too old to raise it much more than 2-3" . What's my best option on the suspension system brand? Also will it affect other things on the truck? Like major adjustment to the headlights, etc. Thanks to anyone for your advise.
  11. Apr 30, 2014 at 5:35 PM
    csuviper
    Broomfield, CO
    Look at the kits on Toyteclifts.com. Either buy from there or piece a kit together from another vendor. OME or Bilsteins will be great kits. Icon and Kings will be the best.
  12. May 2, 2014 at 7:43 AM
    TT-Truckin
    Al
    Washington State
    Tonneau bed cover
    Thanks csuviper!
  13. Apr 17, 2015 at 1:12 PM
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    Dude you just provided a near exact template for how I want mine to look. Great looking truck!
  14. Apr 17, 2015 at 1:19 PM
    zcarpenter92
    Zach
    NE Colorado
    In sig
  15. Apr 17, 2015 at 6:54 PM
    chphilo
    chphilo Tundra addict
    Western PA
  16. Apr 17, 2015 at 10:34 PM
    csuviper
    Broomfield, CO
    Those should be the ones.
  17. Apr 22, 2015 at 6:09 AM
    Primo
    Primo White Tundra
    Primo
    San Antonio, Texas
    2016 SR Double Cab
    Level kit and TRD Pro Grill Installed.
    2 inch lift kit to level the front with the back. Also to be able to accommodate the 275/65R20 tires.
  18. Dec 30, 2021 at 7:53 PM
    Drew1
    Drew1 New Member
    2007 Tundra 5.7 4wd
    Primo, what 2" kit did you use? How did it hold up over time?
