Leveling kit ideas ? Or lift ?
Discussion in 'Suspension' started by Tundra701, Oct 15, 2017.
  1. Oct 15, 2017 at 10:12 PM
    Tundra701
    Tundra701 [OP] New Member
    Tundra trd off road sr5 doble cab
    I'm just wondering what kind of leveling kits is the best for my truck i dont want to go to crazy i just want to make it look good. Keep the same rims and tires ..
  2. Oct 15, 2017 at 10:22 PM
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    Bilstein 5100's on the lowest setting would probably be your best bet if you're sticking with stock rims and tires. But you won't see a big difference unless you change rubbers and rims.
    Law323 and Bob like this.
  3. Oct 15, 2017 at 11:52 PM
    Patriot
    Patriot Member
    Western NC, “Boondocks”
    Make it look good with a Toytec Boss 3/1. :thumbsup:
  4. Oct 16, 2017 at 1:27 AM
    #3 post.. X2 on toytec Boss Kit with some 35s
    Law323, T-Rex266 and Patriot like this.
  5. Oct 16, 2017 at 2:40 AM
    CJ21
    CJ21 CJ-21
    DELAWARE
    2016 Tundra platinum
    Clifford Alarm, 7" BDS lift with Fox coil overs, 20x12 with -44 off set fuel Mavericks , 35" TOYO Open Country Tires , Bush Wacker pocket fender flare ,2" rear Leaf springs, Bull Bar,
    Get A Lift kit..You get a level Kit you will be kicking yourself.....:frusty:
    Patriot likes this.
  6. Oct 22, 2017 at 7:43 PM
    reimord
    reimord New Member
    Another vote on using Bilsteins. They are easy to install and cost effective. Got mine at 4wheelonline. These shocks can improve ride quality and handling.
  7. Oct 22, 2017 at 7:51 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    You can go with Bilstein 5100's. They've got 3 settings. At the top setting your truck will be nearly level. It all depends what you do with your truck. I know a guy here who did the Toytec boss and is now shopping for some serious suspension 'cause he likes to wheel his truck.
    joonbug likes this.
  8. Oct 23, 2017 at 5:11 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
  9. Nov 2, 2017 at 6:10 AM
    Rex Kramer
    Georgia
    Lowering the rear and adding the TRD rear sway bar to my Tundra
    are easily the most rewarding mods I have made to my truck.
    831Tun and GNTundra like this.
  10. Nov 2, 2017 at 8:06 AM
    TundraTss
    TundraTss The Mistress
    Brandon
    2019 TRD SR5
    Everything. Literally.
    @Toytec 3/1 lift kit.
    Pricier than a level but well worth it.
    Buy once cry once.
  11. Nov 2, 2017 at 8:07 AM
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
    Lift
    No leveling
  12. Nov 6, 2017 at 6:46 PM
    Quartermeter
    Quartermeter New Member
    James
    Alabama
    2014 SR5 DC WHITE
    FOX 2.0 REARS, OME FRONTS FIRESTONE AIR BAGS RCI SKID PLATE
    It's a TRUCK...I don't know why you would lower it...JMHO.
    Ely010606 likes this.
  13. Nov 7, 2017 at 3:11 AM
    Rex Kramer
    Georgia
    You lower it if lowering meets your needs.
    Why would you lift a truck if lifting it doesn't meet your needs?
    Ps3udonymous likes this.
  14. Nov 7, 2017 at 4:43 PM
    silverhack
    silverhack New Member
    Sacramento, CA
    2018 CrewMax Inferno
    Because it looks awesome.
