Leveling kit for 35" tires?
Discussion in 'Wheels & Tires' started by Dom87, Apr 24, 2017.
  1. Apr 24, 2017 at 6:29 AM
    Dom87
    Dom87 [OP] New Member
    Nery
    Toyota Tundra
    Wheels
    I want to use 35" tires but dunno if I have to use a leveling kit. Help plz
  2. Apr 24, 2017 at 6:32 AM
    olsin6
    olsin6 New Member Vendor
    Joey
    Mesa, AZ
    2010 White DCSB Tundra
    35" Toyo MT w/ 17" Method Standards Body Mount Chop SDHQ Sliders
    To minimize rubbing, you are going to want to do a 3" lift (I'd recommend a replacement coilover and upper arm) and would recommend doing the body mount chop as well to help eliminate rubbing at full lock.
    Bob, NewImprovedRon and TheBeast like this.
  3. Apr 24, 2017 at 6:39 AM
    Windwarrior
    Windwarrior New Member
    2017 TRD Pro
    Stock
    I have 35x12.50 on my stock TRD Pro. My wheels have a +25 wheel offset. No rubbing, clearances are really close though.
    Mountun Goat, jlee, Puud and 3 others like this.
  4. Apr 24, 2017 at 6:40 AM
    chphilo
    chphilo Tundra addict
    Western PA
    If you want to avoid the body mount chop, try to stay with max of 9 inch wide wheels with 30 or 35 mm offset (in addition to the lift).
    Another option is to go with 295/70/18. They are not quite 35, but close in diameter and narrower. They will give you less problem with rubbing.
    zcarpenter92 likes this.
  5. Apr 24, 2017 at 6:46 AM
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    Welcome from eastern CO!
    Law323 likes this.
  6. Apr 24, 2017 at 7:07 AM
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    Stock Pro you will be fine as long as you do the smaller end 35"
    such as a Ko2.
    Stock rim. Pull some plastic guards off and maybe push a little forward.
    get a good alignment by someone who knows there stuff.
    This setup is very gets the front tires very close to the UCA.
    Few folks I've spoke to ran this exact setup.
    I went with the CB kit.
    Do not put any spacers on. or you will rub all over.
    equin and joonbug like this.
  7. Apr 24, 2017 at 7:10 AM
  8. Apr 24, 2017 at 7:38 AM
    R0CKETMAN
    R0CKETMAN IG: @rocketmanmtb
    NGAMTNS
    '17 TUNDRA TRD PRO CEMENT ‘15 TUNDRA SR-5 WHITE
    As noted
    295/70/18
    No issues
    geno0506 likes this.
  9. Apr 24, 2017 at 9:14 AM
    Vector W8
    Vector W8 Old guy with a lot of expensive habits.
    FFV, TRD Supercharger, Bullydog FFV Tune, 2014 Fit Kit, TRD Dual Exhaust, Sequoia Front Sway Bar, TRD Rear Sway Bar, TRD Skid Plate, TRD Pro Grill, 040 White Mirror Covers, 040 White Door Handles, Ready Lift 3"/2", Anzo 3rd Brake Light, Winjet LED Tail Lights, LED Fog Lights, LED Rock Lights, Axle Vent Mod, SDHQ Hidden Winch Mount, 12,000lb Winch. Storm Trooper Shift Knob. BMF BATL Wheels.
    I have 295/65/20s with a 20x9" wheel and +12mm offset and I rub all over overall diameter is 35.4" with my tires. Its not pretty. Need to clearance the front splash guard and bumper and body mount chop is a must.
  10. Apr 24, 2017 at 9:17 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    3/1 lift with plastic trimming in front wheel well and possibly the need for a cab mount chop (cmc) and you can run 35s
  11. Apr 24, 2017 at 9:45 AM
    Digodell
    Digodell New Member
    Shane
    I had a similar question, please help. Looking to run 285/75 18 on my TRD pro with 2 coachbuilder front shims and rear 3 inch shackles. Anyone running this, I am thinking there should be no rubbing with stock TRD wheels but please help/comment.
  12. Apr 24, 2017 at 9:51 AM
    TheBeast The Beach
    can you get away with 2.5" or 3" is the magic number ? Also if you run aftermarket wheels like the new Icons 17"
  13. Apr 24, 2017 at 12:53 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Welcome from CO.
  14. Apr 24, 2017 at 1:09 PM
    R0CKETMAN
    NGAMTNS
    You'll be fine...assuming you have a tire you dig in that size
  15. Apr 24, 2017 at 1:40 PM
    Digodell
    Digodell New Member
    Shane
    Thanks Rocket Man, yes looking at some Geolanders, want something not so wide but tall. Have them on my Land Cruiser and very satisfied.
  16. Apr 24, 2017 at 5:24 PM
    geno0506
    geno0506 New Member
    Michael
    do you have a view whereI can see how much poke out from fender there is!
  17. Apr 24, 2017 at 5:34 PM
    Windwarrior
    2017 TRD Pro
    Stock
    Chucho and geno0506[QUOTED] like this.
  18. Apr 24, 2017 at 5:39 PM
    geno0506
    geno0506 New Member
    Michael
    Nice truck,
    I just installed some Bilsteins at top setting and am looking at 2.50-2.75" up front now. I have new SCSSR8 18" wheels with a +25 offset waiting to install tires this week. I here most have to do a body mount Chop and I am steering clear of that but would love to put 35/12.50/18's on but most say stick with 295/70/18's.
    What do you have setup wise on your Pro to run these 35's
    Thanks
  19. Apr 24, 2017 at 5:50 PM
    Windwarrior
    2017 TRD Pro
    Stock
    Stock pro lift which i think is 2.5 in higher than a non-pro. I have 18" Method NVs with +25 offset. Had to pull all the mud flaps on the front and tuck the bumper liner on the inside. I been running this setup for 3 weeks and no rubbing yet. It is close though. I pull a trailor and have done some minor offroading on some trails.
    equin and geno0506[QUOTED] like this.
  20. Apr 24, 2017 at 6:34 PM
    geno0506
    geno0506 New Member
    Michael
    Awesome, so you don't need a chop body mount and what brand are your tires!
  21. Apr 24, 2017 at 6:35 PM
    Windwarrior
    2017 TRD Pro
    Stock
    No chop. BFG KO2s
    geno0506[QUOTED] likes this.
  22. Apr 24, 2017 at 6:45 PM
    geno0506
    geno0506 New Member
    Michael
    Thanks for the info!
  23. Apr 25, 2017 at 11:56 PM
    geno0506
    geno0506 New Member
    Michael
    Well I went in to Discount today wanting to ask about Nitto Ridge Grapplers 295/70/18's, I wanted 35/12.50/18 but the guy at Discount said they wouldn't fit without chopping the mount and being that my bilstein 6112's only give me a 2.50-2.75 front lift. The new wheels are 18" and have a +25 offset!
  24. Apr 26, 2017 at 12:01 AM
    Dustydirt19
    Dustydirt19 Hoghead
    Dustin
    Duluth, MN
    2015 Blue Ribbon Metallic 5.7L 4WD SR5 TRD DC
    ProComp 6" stage 2 lift 18x9 Fuel Vapor -12 offset 35x12.5 Nitto Ridge Grapplers BullyDog Tuner Gibson Metal Mulisha cat-back exhaust, S&B cold air intake, Color matched TRD PRO Grille, Compustar Remote Start N-Fab Hooped Nerf Bars, AMI Big stick antenna, Salex organizer and tray, Weathertech laser cut floor mats, Weathertech window deflectors Black out badge Black out front and rear bumper Black out flags 24/7 black out TRD Off-road decals Spray in Line-X Bedliner Scosche phone mount Soft rolling tonneau cover TRD pedals and footrest
    What kind of bumper is that on the other guys truck in the first pic?
  25. Apr 26, 2017 at 12:15 AM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Your tires past fender about. 2 inches?
  26. Apr 26, 2017 at 4:10 AM
    Windwarrior
    2017 TRD Pro
    Stock
    The guy at 4 wheel pros said the same thing. I took the chance and it fit, no chop.
  27. Apr 26, 2017 at 4:11 AM
    Windwarrior
    2017 TRD Pro
    Stock
    Southern Style, it looks awesome.
    Dustydirt19[QUOTED] likes this.
  28. Apr 26, 2017 at 4:12 AM
    Windwarrior
    2017 TRD Pro
    Stock
    I'll measure today and let you know.
    Jsena[QUOTED] likes this.
  29. Apr 26, 2017 at 8:20 AM
    Dustydirt19
    Dustydirt19 Hoghead
    Dustin
    Duluth, MN
    That thing is BAD!!! Going on my list
  30. Apr 26, 2017 at 10:29 AM
    Windwarrior
    2017 TRD Pro
    Stock
    About 1.5 on top an close to 2 on the front.
