Leveling height.
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by Rockstar72, Dec 12, 2022.
  1. Dec 12, 2022 at 7:29 PM
    Rockstar72
    Rockstar72 [OP] New Hampshire in the house
    Kris
    Manchester, NH
    2020 Army Green Toyota Tundra TRD Pro Crewmax
    Hello. I'm looking to level my 2016 Toyota Tundra. What height does everyone usually go with? I'm thinking 2" but I'd like to here what others set their height at. Thank in advance.
  2. Dec 13, 2022 at 1:19 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    factory rake is 2 inches. Pro model is 2 inches higher than the other trims, and level from the factory, for 2nds gens
  3. Dec 13, 2022 at 1:38 PM
    Nbab23
    Nbab23 2020 SR5
    Nathan
    PA
    2020 SR5 crewmax
    Stillen CAI, DD 8” exhaust, Toytec Aluma coilovers, Icon leaf springs, SCS SR8 18x9 wheels, Cooper Rugged Trek 275/70/18 A/T Tires, Ecoological bumper shellz and grill surround, AJT interior black out kit, AJT shift knob. TRD pro style grill, VLED aqua blue footwell lights, MESO custom dome and map LED lights, swing case, Rough country bed mat, TRD pro headlights and fog lights, Morimoto XB tail lights and 3rd brake light.
    Yeah it seems to be 2 inches across the board or pretty close to it. You can always try to find a flat spot, and measure from the ground at the center of your tire up to the wheel well front and back and see what the difference is to be sure. I know for mine, I did 3 in the front and 1-1/4 in the back with a shackle and it looks perfectly level. I had a 1 inch block prior to that (instead of the shackle) and it also looked perfectly level so even if it is a 1/4 inch or so off you'll never be able to tell.
  4. Dec 13, 2022 at 1:42 PM
    1794TX
    Steven
    N.TX
    '20 1794
    I levelled mine with 2.25" Falcon/Teraflex shocks (on stock springs) and added some rake (.75") back with +1 Coachbuilder shackles. Rake would be .5", but I also added about 100lbs. to the front with 3/16" steel engine skid and cat plates, so rake is about 1".
