Leveling a 2015 Tundra TRD Pro
Discussion in 'Suspension' started by GoldStandard, Sep 9, 2018.
  1. Sep 9, 2018 at 7:13 PM
    GoldStandard
    GoldStandard [OP] New Member
    2015 Toyota Tundra SR5 4x4 w/TRD Package
    I want to level my 2015 Toyota Tundra TRD Pro. I have been looking at the Bilstein 5110’s because I see a lot of people recommending them on the forum for leveling but people also say these will put the Tundra at the same height as a TRD Pro. Since I already have the TRD Pro will these shocks level my truck or will it just sit the same as it does now?
    If they won’t work any recommendations to level a TRD Pro?
  2. Sep 9, 2018 at 7:13 PM
    crochetjohn
    crochetjohn New Member
    2015 Inferno TRD Pro
    TRD Pro comes leveled on Bilstein's. Are you positive you have a pro?
    Edit: Also lets see some pics.
    drhntr, Marty McFly and Sas like this.
  3. Sep 9, 2018 at 7:18 PM
    lionix
    lionix The Grey Moose!
    Cape May, New Jersey
    2017 Tundra TRD Pro CM Cement
    BD Lights, Any Time Fog, Coachbuilder, Pelfreybilt, Bakflip, Custom Bed Rack w/ Tent
    It will sit at a similar height. But your ride will be worse.
    A TRD Pro is leveled.
  4. Sep 9, 2018 at 7:22 PM
    TaquitoBandito
    Joel (AKA Bif)
    Yeah, I kinda did a double take at this one...
  5. Sep 9, 2018 at 7:26 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Maybe the previous owner put on an add a leaf, block or rear leaf pack? It should be level from the factory if it's a stock trd pro
    lionix, Blueknights75 and Sas like this.
  6. Sep 9, 2018 at 7:56 PM
    Blueknights75
    Ron
    Clayton, NC
    Welcome from NC!
    :worthless:
    lionix likes this.
  7. Sep 12, 2018 at 1:43 PM
    GoldStandard
  8. Sep 12, 2018 at 1:46 PM
    GoldStandard
    It is definitely TRD, and as far as I know it’s stock.
  9. Sep 12, 2018 at 1:48 PM
    Rica25
    Ricardo
    Tulare
    It's not TRD PRo its only a TRD
  10. Sep 12, 2018 at 1:49 PM
    Rica25
    Ricardo
    Tulare
    Only the Pro comes leveled your has 4600 billstein shocks
    TaquitoBandito likes this.
  11. Sep 12, 2018 at 1:50 PM
    Rica25
    Ricardo
    Tulare
    The TRD Pro has different shocks and many more upgrades also has TRDPRO stamped on the bed
  12. Sep 12, 2018 at 1:51 PM
    crochetjohn
    What they said ^
    So yea, Go with the 5100 or 6112. That should bring the front up 2 inch or so. Others may be more specific.
  13. Sep 12, 2018 at 2:02 PM
    PMG
    PMG New Member
    Do the 5100s all around, top setting up front and a coachbuilder shim on the driver side and you're done.. Install the rears yourself as it takes 30 min.
    crochetjohn likes this.
  14. Sep 12, 2018 at 2:02 PM
    GoldStandard
    The only TRD Tundra in 2015 was the Pro
  15. Sep 12, 2018 at 2:06 PM
    crochetjohn
    The TRD 4x4 is an SR5 with an offroad package. The TRD PRO's most notable difference is that it has embossed bedsides.
    drhntr likes this.
  16. Sep 12, 2018 at 2:07 PM
    crochetjohn
    Like this.
    lionix, drhntr and Marty McFly like this.
  17. Sep 12, 2018 at 2:08 PM
    TRDProLife
    TRDProLife LETS GO BLUES
    St.Louis
    Barcelona Red Metallic TRD Pro Tundra
    Window Tint, ICI Magnum Steps, firestone spring helpers for towing, 295/70R18 Atturo Trsil blade X/T's
    I'm starting to feel bad for you. Did they sell it to you as a TRD PRO? It definitely is not a Pro. 2015 Pros came in inferno orange, black, and white. And all pros have embossed TRD PRO in the side if the bed black leather interior with red stitching, bilstine shocks etc... sorry bud.
    drhntr and crochetjohn like this.
  18. Sep 12, 2018 at 2:11 PM
    TRDProLife
    St.Louis
    You didnt notice the badge that says SR5?
  19. Sep 12, 2018 at 2:14 PM
    16TRD
    16TRD New Member
    Norcal
    2016 White crewmax
    Did the delear you got this from pass this off as a pro? I see alot of dealers try to do this on some of the ads ive seen. You definately have the trd offroad trim level. Like others have said you can level it with some bilstein 6112
  20. Sep 12, 2018 at 3:00 PM
    GoldStandard
    So since I drive mostly on the hard road are the 5110 or 6112 a better option? From what’s I understand the 5110 are a smoother ride on the hard road but see a lot of different opinions on here.
    Also should I do the same shocks in the back or are the stock Bilstein shocks fine?
    Last question for now, will I need a front diff drop kit if I do get the 5110 or 6112 and lift up the front?
  21. Sep 12, 2018 at 3:18 PM
    TRDProLife
    St.Louis
  22. Sep 12, 2018 at 3:49 PM
    crochetjohn
    I have zero experience with either. I have heard good things about both though. On road they're prolly both great.
    If you're on a budget go with the cheaper of the two and only do the fronts.
    I don't think you need the diff drop unless you start going 3/1 level.
  23. Sep 12, 2018 at 3:55 PM
    drhntr
    drhntr New Member
    Derrick
    New Hampshire
    2017 Cement Pro DC
    GoRhino 2.0 Diamondback Switchback 295/70/18 TOYO AT3 TRD CAI Window Tint
    God I hope they didn’t upcharge you and tell you it was a PRO. You have a trd package on a SR5. All pro’s come with a TRD PRO bed stamp
  24. Sep 12, 2018 at 6:38 PM
    Rica25
    Ricardo
    Tulare
    They also come with much different shocks and also TRD exhaust and seats that say TRD pro
    Marty McFly and crochetjohn like this.
  25. Sep 12, 2018 at 6:42 PM
    Rica25
    Ricardo
    Tulare
    They also come with much different shocks and also TRD exhaust and seats that say TRD Pro
    Marty McFly likes this.
  26. Sep 12, 2018 at 6:46 PM
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    OP do u have a pic of your ride?..please share.
  27. Sep 12, 2018 at 6:46 PM
    crochetjohn
    He did, It's up there.
  28. Sep 12, 2018 at 6:57 PM
    saybng
    Gary
    Ventura CA
    Oh snap..you are correct..forgive me..I've must of passed it..:mudding:
  29. Sep 12, 2018 at 6:58 PM
    crochetjohn
    All good, It's a TRD 4x4. Hopefully they didn't sell it to him as a TRD Pro.
  30. Sep 12, 2018 at 7:07 PM
    Rica25
    Ricardo
    Tulare
    I would go back to selling dealer and give them shit
