Leveler kit rattle
Discussion in 'Suspension' started by Justin 2020 Crew, Aug 3, 2022.
  1. Aug 3, 2022 at 8:43 AM
    Justin 2020 Crew
    Justin 2020 Crew [OP] New Member
    Justin
    I recently installed a 2' leveler kit to my stock SR5 Crewmax, it drives nice and straight
    but I am hearing a rattle on the right side now, almost sounds like the coil is rattling on the shock when I hit bumps, anyone have any insight on this?
  2. Aug 3, 2022 at 9:41 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    could be so many things, first would be checking all the bolts and fasteners you touched for correct torque. Did you r%r lower control arms? Did you torque fasteners while truck in the air or with weight on the ground?
  3. Aug 4, 2022 at 8:02 AM
    Justin 2020 Crew
    Justin
    I didn’t do the work myself, I took it to someone I trust, I’ve been back twice he says everything is tight, it’s just the right side it’s sounds like metal washers jingling or shock isn’t seated correctly? Does the two inch lift in the front mess with the geometry that much to need other adjustments? Is it possible that right side isnt sitting in the holder correctly?
