Leveled w/ new rubber
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by Finch, Feb 26, 2020.
  1. Feb 26, 2020 at 4:37 AM
    Finch
    Finch [OP] New Member
    Donnie
    '16 Inferno CM 5.7L TRD Off-Road
    I installed my 5100s last weekend all the way around with the fronts on the middle setting. Upsized a tad to Cooper Discoverer AT3 XLT's in 275/70/18 yesterday and I think it turned out great! I have a slight rub I have to iron out but I'm happy with the stance. It almost looks nose high in the bottom pic but my measurements say otherwise. (Top 2 pics are a full tank of gas and bottom is 3/4). I think my driver side is a tad lower but I can live with that. Not worth it to me to add a shim.
    I'm wanting to powdercoat the stock wheels to black but the shop needs my truck for 2 weeks. We'll see...
  2. Feb 26, 2020 at 4:45 AM
    Bad Cow
    Bad Cow GOD Bless The USA
    Georgia USA
    2019 TRD PRO - SUPER WHITE
    Leather Steering Wheel, +1.5" Shackles
    I prefer the rake myself. When the truck is dead level, then when you tow or haul anything your ass end sags. My PRO sits almost level from the factory, and I want more rake. Thinking WIRELESS AIRBAGS for towing.
  3. Feb 26, 2020 at 4:50 AM
    Finch
    Donnie
    Yeah, definitely is a tradeoff with leveling one out. I sometimes tow a pop up camper but mostly don't tow. I'll live with the nose high syndrome during those times.
    Boerseun likes this.
  4. Feb 26, 2020 at 4:55 AM
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    That looks good. I have a small lift (3/1.5) with my leveling, and have been thinking about removing it; just a small level in the front.
    HbbTundra08 and Finch[OP] like this.
  5. Feb 26, 2020 at 5:01 AM
    SprinterAE86
    SprinterAE86 New Member
    Ian
    Charlottetown, PE, Canada
    2012 Toyota Sequoia Platinum
    What's your measurement hub center to the fender?
    I use the airbags to add rake on mine.
  6. Feb 26, 2020 at 5:40 AM
    Bakelite
    Bakelite New Member
    Sam
    2018 Toyota Tundra TSS 4x4
    The tires definitely completed the look - looks great!
    Finch[QUOTED][OP] likes this.
  7. Feb 26, 2020 at 6:34 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Nice. I will get running those tires and size when it comes time to replace them this spring/summer. However, no lift/level in my plan for now as the truck does not have a ton of miles....I will lift once I need to replace shocks or other wear items.
    Finch[OP] likes this.
  8. Feb 26, 2020 at 8:01 AM
    Creatures 1982
    Creatures 1982 New Member
    2017 SR5
    OP
    Put ride rite bags on back, at 5 psi you will be level again. Just food for thought.
    Then your also good to go when hauling heavy loads.
  9. Feb 26, 2020 at 1:18 PM
    Finch
    Donnie
    I took these measurements on this road which appears to be fairly level and with a full tank of gas.
    Stock height measurement vs 5100s installed:
    LF: 21 7/8" to 23 5/8"
    RF: 21 5/8" to 23 7/8"
    LR: 23 1/4" to 23 1/2"
    RR: 24 1/8" to 24"
    I'd like to remeasure on a garage floor or something. My LF measurement was higher than RF before 5100 install and then lower than RF after 5100 install. Probably error on my part.
    Which bags do you have?
  10. Feb 26, 2020 at 1:20 PM
    Finch
    Donnie
    I checked them out. Some seem like they are difficult to install. I never thought I'd consider them but I'll see how bad the front is nose high when I hook up the camper.
    Say you installed bags but left them deflated for whatever reason (neglect, forget to keep air in them, etc). Does that matter or affect ride quality at all? Don't know much about them.
  11. Feb 26, 2020 at 2:03 PM
    Creatures 1982
    2017 SR5
    Op
    You have to maintain a minimum 5 psi in both bags per Firestone.
    The bags are not difficult to install in my opinion.
    I don’t notice any ride difference at 5 psi
    Finch[OP] and Bad Cow like this.
  12. Feb 26, 2020 at 3:22 PM
    Squeaky
    Squeaky New Member
    Wisconsin
    ‘19 White TRD Pro
    Looks great! I installed the Firestone airbags on my Pro a couple weeks ago to use while towing my boat. Not a bad install at all. With the min psi of 5#, it raised my rear 0.5”. I have noticed a slightly rougher ride with the 5#, but it’s pretty minimal.
    Creatures 1982 likes this.
  13. Feb 26, 2020 at 6:24 PM
    Finch
    Donnie
    Nice. So I know it's only been a couple weeks but is your plan just to keep a check on the pressure every couple weeks so they don't leak out? Not sure I want something else to have to keep up with. Still really don't know if I'd even need them anyway. .
  14. Feb 26, 2020 at 7:10 PM
    Squeaky
    Squeaky New Member
    Wisconsin
    ‘19 White TRD Pro
    Checked all the connections in detail for leaks after the install. Everything was good. A week later, I checked the psi with a digital meter and was perfect. I probably won’t check them again, other than airing up/down for towing purposes.
  15. Feb 26, 2020 at 7:36 PM
    Finch
    Donnie
    Did you run the air line out to the rear bumper area for easy inflating?
  16. Feb 26, 2020 at 7:45 PM
    Squeaky
    Squeaky New Member
    Wisconsin
    ‘19 White TRD Pro
    I drilled out holes on each side of the license plate.
  17. Feb 26, 2020 at 10:27 PM
    Bravohook
    Bravohook New Member
    Addame
    NY
    2007 RCSB
    Cool Things
    Looks great!! I just put 5100's all around on mine as well. I'm almost dead even currently but I have 360lbs in the bed for winter. Still on 275/65-18's when I took the sand bags out it lifted the rear .75" so I have a little rake. I also did not have any front end lean like most mine was in the rear due to the fuel tank but it's not noticeable. I love the ride of mine. Had them on for a few weeks and the fronts are starting to settle in and smooth out a bit.
  18. Feb 26, 2020 at 10:36 PM
    Finch
    Donnie
    I'm loving the ride with the new shocks as well. Definitely feels better in the curves. I know it only leveled the truck and I gained an inch with the bigger tire but it feels higher than that. Completely happy!
  19. Feb 26, 2020 at 10:46 PM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Want better performance on turns and curves?
    TRD rear sway bar....
  20. Feb 26, 2020 at 10:56 PM
    Finch
    Donnie
    Researching now...:)
    1lowlife[QUOTED] likes this.
  21. Feb 27, 2020 at 5:52 AM
    gupster88
    gupster88 New Member
    Brett
    Charleston, WV
    2019 Toyota Tundra SR5 TRD Off-Road
    Looks GREAT! Thanks for the comparison pics, this is what I'm looking at doing. Been trying to convince the wife that the middle setting level with 275/70s makes a huge difference but she hasn't been able to see a comparison picture like this until now!
  22. Feb 27, 2020 at 8:26 AM
    1lowlife
    1lowlife New Member
    DADA
    2014 MGM DC SR5
  23. Feb 27, 2020 at 9:20 AM
    MARanger
    MARanger Lost in the woods
    Andy
    Home of Friendly's Ice Cream
    2017 Super White SR5 DC 4X4
    Looks good
  24. Feb 28, 2020 at 4:42 AM
    gupster88
    Brett
    Charleston, WV
    How come? Better ride or just want less lift?
  25. Feb 28, 2020 at 4:46 AM
    Boerseun
    Ferdie
    Sarasota Florida
    I break my ankle every time I jump out!
    Just kidding. I am 6'-4" so getting in and out in itself is not a problem, but it just feels that it is that one inch too high to comfortably slide in and out. Too high to slide in and too low to really step up. An inch lower will be the sweet spot for me.
  26. Feb 28, 2020 at 4:57 AM
    gupster88
    Brett
    Charleston, WV
    Ah ok I gotcha. Makes sense lol. Was hoping you'd say something about lift is too rough haha. I've gone back and forth on the 3/1.5 lifts and the bilstein 1500 middle setting. Love the 3/1.5 look but I wonder about it being too high as well.
  27. Feb 28, 2020 at 5:06 AM
    Boerseun
    Ferdie
    Sarasota Florida
    Yes, there are a lot of discussions about the ride getting rough but that is not really true - it's the same spring and shock as OEM, so the ride is the same, just higher. I won't open that can of worms though - it has been discussed to death elsewhere.
    One other reason I would lower it, is that with the 3" spacer you have to add a bump stop spacer to keep the shock from bottoming out. This reduce your up-travel. I drive on construction sites every day and although I never had issues with it, I know that I hit the bump stops all the time. The 5100 shock is a different length and will allow more travel, if that would be a consideration or you.
  28. Feb 28, 2020 at 7:45 AM
    gupster88
    Brett
    Charleston, WV
    I've had enough trucks with spacer lifts to know how they ride and the advantages/disadvantages of them. I'm a pavement princess not a rock warrior so that doesn't bother me. Was just debating on the overall height and if wife and kid would complain about or not haha.
    Boerseun[QUOTED] likes this.
