Level without lifting
Discussion in 'Suspension' started by tjthescott, Jan 14, 2024.
  1. Jan 14, 2024 at 10:37 AM
    tjthescott
    tjthescott [OP] New Member
    Does anyone have pics of a 2.5gen platinum with the rear lowered 2-3" for levelling (not squatted). I know its sacrilege to some to not lift the front, but I don't care for how they look lifted in the front with stock wheels and tires. Because it's a platinum I'd like to retain the luxury look rather than an off-roading look. I'd just like to see what one looks like leveled from the rear.
  2. Jan 14, 2024 at 10:50 AM
    blenton
    blenton New Member
    I know there are a couple of guys here that have done it. There’s actually a guy down the road from me that’s done it. Definitely borderline sacrilege. Haha
  3. Jan 14, 2024 at 11:45 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Minimum you can lower the rear is 4” and that’s with an axle flip. There are no blocks on the axles of these trucks. It’s not a GM where you can remove the block and get a drop shackle. For that reason, the most common drop is a 2/4 (front/rear) and that’s the only kits you’ll readily find.
  4. Jan 14, 2024 at 11:58 AM
    tjthescott
    Well there’s my answer. I’ll leave it alone, don’t want it looking too low or make it squat
  5. Jan 14, 2024 at 12:02 PM
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
    Throw a few hundred pounds in the bed?
  6. Jan 14, 2024 at 1:19 PM
    blenton
    blenton New Member
    If you spring under with a longer shackle you can get a 3” or 2” drop. The rake on our trucks is about 3”, but because of the body lines 2” looks level, IMO.
  7. Jan 14, 2024 at 1:26 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Longer shackle gives lift with no load, but it make the travel longer under load
  8. Jan 14, 2024 at 2:00 PM
    Danman34
    Danman34 New Member
    Danny
    Right. But you’re still doing an axle flip regardless.
  9. Jan 14, 2024 at 2:19 PM
    blenton
    blenton New Member
