Level Trd pro with just shims??
Discussion in '3rd Gen Tundras (2022+)' started by Aks74u, Sep 30, 2023.
  1. Sep 30, 2023 at 7:30 AM
    Aks74u
    Aks74u [OP] New Member
    2024 met gray TRD PRO
    Nitro Recon Grappler 305/70/r18 Trd steps Bed step Dash cam Console safe Bed extender Ceramic tint
    Not sure if this has been done before but I would like to level/get just a tad of lift on my 2024 pro without changing the preload/spring rate. Correct me if I’m wrong but it seems a small shim lift would achieve this without changing the quality of the fox shocks’ ride. I see coach builder makes .5 and inch shims and I’m sure the ones out of the wescott kit would work as well. Any input is appreciated thanks guys!
  2. Sep 30, 2023 at 10:27 AM
    itundra22
    itundra22 New Member
    2024 MGM Limited Hybrid 4x4
    I just ordered steel shims from cornfed "1/2" thick zinc plated steel shims to provide 1" of front lift" per the description from the site. Have not installed them yet. Could be something to consider for yourself since you're not looking to get a big increase in the lift.
  3. Oct 3, 2023 at 4:35 AM
    grnwdjsn
    grnwdjsn New Member
    2023 Tundra Limited TRD Offroad
    I put the 1.75" Rough Country leveling kit on mine and it was pretty easy. Only tough spot was compressing the spring and turning the top plate a bit. The truck measures level, but I always have the slight impression that the front looks a tiny bit too high. I can live with it, and am probably the only one to notice it. It really depends on the angle up/down my truck is sitting. Hindsight, I would have targeted a 1" lift.
  4. Oct 3, 2023 at 3:06 PM
    Black widow TRD
    Black widow TRD New Member
    Manuel
    2023 Black Tundra SR5/TRD
    Cornfed makes good shit. I’d do it, for the leveled look.
    itundra22 likes this.
  5. Oct 3, 2023 at 3:09 PM
    Wait, I thought TRD Pros were level from the factory….
  6. Oct 4, 2023 at 9:08 AM
    osu1978
    osu1978 New Member
    My 2023 is around 3/4” higher in the rear with a bed cover, mat and misc stuff in the bed.
  7. Oct 4, 2023 at 10:47 AM
    One bag of dogfood in the back of a fully leveled truck and you’re squatting. Need a little rake to carry some load without dragging ass. 3/4” is pretty close to level and gives a little load carrying prior to showing squat.
    matth66 likes this.
