Level kit
Discussion in 'Suspension' started by 05newb, Apr 18, 2016.
  1. Apr 18, 2016 at 8:33 AM
    05newb
    05newb [OP] New Member
    '05 SR5 Access Cab-2wd-4.0L
    K&N intake, Removed badges
    just wondering if anyone has experience with this day star 1" kit. It's super cheap but says its USA made.
  2. Apr 18, 2016 at 8:39 AM
    "It's super cheap" --- my .02 is you get what you pay for. Save up for the kit you really want.
  3. Apr 18, 2016 at 8:55 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Looks like an in-coil spacer. Will need to pull apart the coilover assembly and replace. Did a quick search and the daystar website only has a 2.5" level spacer (part# KT09103BK)
    The 1" you show above wont level the truck.
  4. Apr 18, 2016 at 9:05 AM
    05newb
    Then what will it do?
  5. Apr 18, 2016 at 9:23 AM
    csuviper
    Broomfield, CO
    2" to 2.5" should get your front level with the rear.
  6. Apr 18, 2016 at 9:26 AM
    05newb
    Well, I measured the rear fender at 35" from the ground, and the front at 34" from the ground. Unless I'm not understanding something then that 1" spacer would make it exactly level right?
