Let's talk towing capacity!
Discussion in 'Towing & Hauling' started by racervx54, May 16, 2015.
  1. May 16, 2015 at 5:34 AM
    racervx54
    racervx54 [OP] New Member
    2015 trd pro inferno
    Ok 2015 cm trd pro here. What's the difference between the 7200 lbs and the 10k towing capacity? I am assuming the only difference is the hitch. Class 3 vs Class 5? Anyone have any info?
    Reason I am asking I have a 28 ft enclosed at about 8000 to 8500 lbs.
    Thanks
  2. May 18, 2015 at 8:25 PM
    LM_Tundra
    LM_Tundra New Member
    Richard
    Southern California
    Tundra 1794
    Look in your owner's manual. Find your truck Model code and engine size and you'll have what you're looking for. Just be sure and watch all the fine print and foot notes.
  3. May 29, 2015 at 1:21 PM
    racervx54
    Yea i read that. I guess my question is what's the difference between the 7,200lbs and the 10,000lbs. Is it the hitch because everything else is the same.
  4. May 31, 2015 at 4:28 PM
    Rkcruza
    Rkcruza New Member
    Bob
    2002 Tundra AC 4WD TRD OR SR5
    De Badged / Decaled, Firestone Ride Rite Air Bags w/ Daystar Cups, 17" Rims, Big Brake kit w/ slotted & drilled rotors, plus lots of work related stuff.
    Not sure what they do on the Tundras...on the Tacos (3500# vs 6400#) the difference is a Class 4 hitch, 7 pin connector, wiring for a brake controller, tranny cooler, engine oil cooler, and some computer controlled sway control stuff. Look in the specs and see what is listed on the Tundra in the Factory Tow package...could be quite a bit. Usually the lower rating is simply a Port installed hitch and a trailer plug. I assume the Pro comes with the 5.7? My 1st gen has a 4.7 and it has a 7400# rating with factory tow package.
  5. May 31, 2015 at 6:46 PM
    One thing to consider is that the 5.7L Tow package option also includes rear leafs with increased spring rates over stock setup and 4.3:1 diff giving it the higher tow rating
    zcarpenter92 likes this.
  6. Apr 19, 2016 at 9:52 AM
    MillsTRD14
    MillsTRD14 New Member
    Aaron
    2014 Tundra TRD
    Ba mufflers 7 inch, Bilstein 5100 TRD strut bar, Firestone adjustable ride rite airbags, tow mirrors , BFGoodrich ta ko2 33s, TRD shift knob, blacked out emblems, tundra Pro grill......
    Or you can install these
    zcarpenter92 and NewImprovedRon like this.
  7. Apr 19, 2016 at 12:29 PM
    DBL TAP
    DBL TAP Light 'em up
    USA
    My TRD Pro has a REDUCED leaf spring rate. Payload is reduced by 55 lbs.
    Payload is now 1185 lbs. Tow capacity is 9,200. If I towed a 9000 lb. TT, with a 900 lb tongue weight (10%), my remaining payload would only be 285 lbs. I weigh 208, so now I can only put 77 lbs. of stuff in the bed! So technically, you can be rated to pull a trailer that weighs x amount of pounds, but with hitch weight, fuel, camping items, and people, your tow vehicle could be overloaded.
  8. Apr 19, 2016 at 3:25 PM
    jberry813
    jberry813 The Mad Scientist Staff Member
    Lake Tahoe
    2015 Tundra Platinum, 2012 Tacoma, 2007 T4R
    Metric shit ton of parts
    Doesn't change your tow capacity.
  9. Apr 19, 2016 at 6:13 PM
    And remember to disconnect if you do any serious off roading.
  10. Apr 19, 2016 at 6:31 PM
    DBL TAP
    USA
    Hey Matt, I think he's referring to the air bags.
  11. Apr 19, 2016 at 6:33 PM
    Dang it!!! :thumbsup::frusty::frusty:
    Red Freighter likes this.
  12. Apr 19, 2016 at 6:37 PM
    DBL TAP
    USA
    Must be really cold up there. Come down to SoCal and thaw out.
  13. Apr 19, 2016 at 6:42 PM
    Be a cold day in hell before I ever go back to LA LA land. I wasted 17 yrs there in aerospace calibration. I'm not compatible with CA anymore. I'm into freedom and the 2nd amendment and the EPA, CA cafe stds keeping me from doing anything realistic with my truck or property. :oldglory:
    ColoradoTJ likes this.
  14. Apr 19, 2016 at 6:42 PM
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    I wouldn't worry too much. A Tundra can pull 12,000-13,000 lbs reliably, so if you're over the GVWR by 500-1000, eh.
  15. Apr 19, 2016 at 8:58 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Geeeez. LOL
  16. Apr 20, 2016 at 5:24 AM
    Hell is cold...Actually, I do go back to SOCAL every summer. Most of my brothers and sister, mom still live in the Anaheim Hills and Irvine area. I like to visit and check out my Dodgers, but I could never live in Nanniefornia again. No freakin way.
    Wynnded[QUOTED] likes this.
  17. Apr 20, 2016 at 10:29 AM
    jberry813
    Lake Tahoe
    Let's keep in mind that GVWR, GCWR, and max tow capacity are designed as maximums. The ratings are determined by engine output, axle ratios, vehicle structure and weight, chassis design, suspension design, hitch class, tire ratings & load capacity, cooling capability, brakes, etc. It's not arbitrary and the values set are to keep you, passengers, and surroundings safe.
    Some people thing "heck I added a supercharger, now I can haul more." It's not just power output. In fact, if you have a s/c installed by the dealer, they add a sticker to the door jam stating that GVWR is REDUCED by 13 pounds due to the extra weight of the s/c and components.
    GVWR specifically is based on federal restrictions. The vehicle has to meet federal stopping requirements. Max tow capacity is founded on the SAE JS807 standard. Think of these as semi torture-tests that include handing performance (under/over steer, trailer sway), braking performance (stopping distance as well as parking brake hold on an incline), structural performance on the hitch, acceleration and braking performance on a level road and 12% grade, cooling capacity in the middle of a fucking desert. Again...not arbitrary. Be smart, tow safe.
    Lindenwood, Wynnded, csuviper and 2 others like this.
  18. Apr 20, 2016 at 3:53 PM
    jberry813
    Lake Tahoe
    Uhh...I mean "RAWR! I'm angry! Fuck everybody! Ignore facts and give only opinion. Look at my avatar. RAWR!"
  19. Apr 20, 2016 at 3:59 PM
    jberry813
    Lake Tahoe
    I don't get a lot of compliments. Wasn't sure how to react.
  20. Apr 20, 2016 at 4:06 PM
    DBL TAP
    USA
    This forum obviously doesn't censor crude language, but I do. Compliment has been deleted.
  21. Apr 20, 2016 at 4:08 PM
    jberry813
    Lake Tahoe
    Eh? I guess I forgot the sarcastic font.
    Didn't mean to offend. Those that know my "normal" post style would have understood. :cheers:
    T-Rex266 and zcarpenter92 like this.
  22. Apr 20, 2016 at 4:19 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Its just Jason.
    Knowledgeable and we do appreciate the facts you provide. THANK YOU AGAIN JASON!
    T-Rex266, mdavis, jlee and 1 other person like this.
  23. Apr 20, 2016 at 4:22 PM
    DBL TAP
    USA
    Hey Matt,
    You are welcome here anytime my friend. I totally understand where you are coming from. I will no longer be posting on this forum. Contact the moderator guys, they'll have a phone number for you. God bless you. Jesse.
  24. Apr 20, 2016 at 4:45 PM
    mdavis
    mdavis I need a beer.
    Michael
    Rock Hill, SC
    Really dude? Your getting butt hurt because a guy said fuck on a truck forum?!? Get real for fuck sake.
  25. Apr 20, 2016 at 5:10 PM
    jlee
    jlee New Member Vendor
    jerry
    Bay area CA
    2016 TRD Off Road on 35's supercharged and Kings and A 2002 SAS'ed supercharged Tacoma on 37's Linked front and rear
    Oh one or two.
    jberry813 and mdavis like this.
  26. Apr 20, 2016 at 5:12 PM
    mdavis
    Michael
    Rock Hill, SC
    I swear to you I thought about that when I was posting my comment! Funny shit!
  27. Apr 20, 2016 at 5:15 PM
    jberry813
    Lake Tahoe
    mdavis likes this.
  28. Apr 20, 2016 at 5:15 PM
    jlee
    jerry
    Bay area CA
    Oh one or two.
    So did I I had to find the clip!
    mdavis[QUOTED] likes this.
  29. Apr 20, 2016 at 5:40 PM
    Keep in mind not everyone talks like a sailor and appreciates a good cuss session like some of us.
    People come and go, that is as constant as concrete turning gray and cracking.
    Hope you reconncider @DBL TAP
    zcarpenter92 and jberry813 like this.
  30. Apr 20, 2016 at 5:42 PM
    You know I used to hate Jason, but with passion lol.
    He's one of those guys once you get to know, he truly means well and is only providing his (respected) input.
    Jason once told me "I don't care if I see my worst enemy on the road, stranded, stuck, etc. I will still go out and rescue him to ensure he's ok."
    He said this in-person to me, and was sincere. Does he always have the best way with words? No sir, but it's just how he is. He's one of those guys you meet in person, and is truly a good dude with a real sense of humor. He's got my approval :thumbsup:
    AndyTRDLimited, jlee and mdavis like this.
