lets install some running lights! mspaint inside!
Discussion in 'Lighting' started by InsaneAuto86, Feb 12, 2020.
  1. Feb 12, 2020 at 2:22 PM
    InsaneAuto86
    InsaneAuto86 [OP] New Member
    SE PA
    2020 Tundra SR5 TRD
    Spoiler pic:
    I want some running lights in my Tundra. I personally like the look. These are the LED bolt lights I am using @ $4/ea
    I was going to use the bulge, but the insert is plastic-weld and bolted to the bulge. It looks water-tight and do not want to hack it open, exposing the engine bay to water. Also, personal preference, I do not like running wiring thru the hood.
    So, next best thing, the grill. First idea is a bar. I purchased a piece from HD and cut to length, slightly over 44", and gave it a slight bend to fit the grill profile.
    Now how to secure it?
    I had two ideas, a support bar using the OE grill bolt locations.
    Second idea, epoxy a bolt inside the pocket from the rear of grill. Bolt bar to grill.
    (view from top)
    Then I thought, to independently mount the lights. So I cut out the shape of the grill in 5 rigid black plastic panels from a cardboard template. I will epoxy them to each of the rear grill openings.
    So this is where I'm at. I'll be pulling the grill this weekend. Hopefully epoxy will hold the plastic inserts in place. Then just drill the center hole for the bolt lights and wire it up! More to come...
    Sas likes this.
  2. Feb 12, 2020 at 2:25 PM
    InsaneAuto86
    SE PA
    2020 Tundra SR5 TRD
    I got the grill pulled (even though its single digits outside) and inside the house to warm up. Had some minor fitting to do on the tabs, and used a step bit to drill the center hole. I then put a dot of hot glue on the front to hold the tab in place, then used epoxy on the rear. The hot glue pulled right off after the epoxy was set, leaving no marks/residue. After a few hours cure time, I finished the wiring. All black to a common ground, all hot to common hot. I continued with 22g to extend the LED wiring and am using 14g to circuit termination.
    UPDATES:
    and done... add-a-fuse to INJ. Any suggestion on a dif fuse location so they are only on with the other lights?
    Trooper2 and Sas like this.
  3. Feb 12, 2020 at 2:54 PM
    Captainjohn
    Captainjohn New Member
    2019 Tundra Dbl cab
    Rock sliders, topper, sliding bed
    I’m having some blocks 3D printed to fit in grill , 4 of them with amber LED’s so I Don’t look like a Ford ! Should have them next week.
    InsaneAuto86[OP] likes this.
  4. Feb 12, 2020 at 3:14 PM
  5. Feb 12, 2020 at 3:51 PM
    InsaneAuto86
    SE PA
    2020 Tundra SR5 TRD
    I thought of that, but dont have a file to print from. Each opening is slightly different. How did you get a file?
  6. Feb 12, 2020 at 3:57 PM
    throughitalldude
    throughitalldude New Member
    Jeff
    Southern California
    2017 Platinum
    3/1 Lift |TSS 20" Wheels | 35 Cooper AT3 XLT | Flowmaster 40 Series Exhaust
  7. Feb 12, 2020 at 4:39 PM
    Midnite72
    Midnite72 Anything DIRT !!
    Bill
    Northern MD
    18 SR 5.7 4x4
    2” level P&P sliders
    Great idea !
    Glad someone else feels same as me on the “Raptor” 3- amber copycat !
    :poking:
  8. Feb 12, 2020 at 5:08 PM
    Berdine
    Berdine Voodoo Sport
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    Have you checked out yota leds?
    I did Amazon ones in my bulge on my other tundra, lasted few months before they had water in them then stopped working
  9. Feb 13, 2020 at 4:14 AM
    InsaneAuto86
    SE PA
    2020 Tundra SR5 TRD
    Over $100 for $4 LEDS, a $5 add-a-fuse and some wiring.... ya no thanks
    These are IP65 weather rated and 2 year guarantee for $4.
    Sas and BrandonL812 like this.
  10. Feb 13, 2020 at 5:58 AM
    coTony
    Tony
    Montrose, CO
    Agreed, the price is high for what you get for sure. Have you tried a two piece mounting approach? One piece on the outside of the grill that fits in the hole but will not go through with another piece inside that is basically the same just shaped to fit inside. The hole in the 2 pieces allows for the light to pass through then tighten the mounting nut to compress the 2 together like a "running light sandwich"
  11. Feb 13, 2020 at 9:23 AM
    paradizecityz
    paradizecityz New Member
    Richmond, TX
    2022 Tundra TRD Off Road
    I have the grill lights as well. I got a bracket with a hole in the middle, put the lights and wiring through and use a nut to hold it in place
  12. Feb 16, 2020 at 2:52 AM
    InsaneAuto86
    SE PA
    2020 Tundra SR5 TRD
    More pics up.
  13. Feb 16, 2020 at 4:41 AM
    Captainjohn
    2019 Tundra Dbl cab
    Update ; 3D print file was designed by my son. Light blocks are printed, have amber LED’s and wiring to complete project. Hope to get it completed next weekend, will take photos and post here.
  14. Feb 16, 2020 at 5:04 AM
    InsaneAuto86
    SE PA
    2020 Tundra SR5 TRD
    Would you be willing to send me the file?
  15. Feb 16, 2020 at 6:26 AM
    InsaneAuto86
    SE PA
    2020 Tundra SR5 TRD
    pics added post #2
    2chains, 16 blue crewmax and Sas like this.
  16. Feb 16, 2020 at 6:40 AM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    Good work. I have those same bolt lights from them and was looking to do something similar. What did you use for the plastic backing?
  17. Feb 16, 2020 at 7:01 AM
    Captainjohn
    2019 Tundra Dbl cab
    I have a 19 Limited, lots of different grill configurations, design is set up for this grill only. I might have another upgrade to my block that I might consider doing. Let’s get it figured out first, and then take it from their.
    I’m not sure if he will send file, we did this on another project, and the guy we sent it too started selling parts off our work on eBay....
    My son is a Aerospace engineer, with lots of student loans to pay for his talents. He said maybe we should sell these ; time will tell.
  18. Feb 16, 2020 at 10:11 AM
    InsaneAuto86
    SE PA
    2020 Tundra SR5 TRD
    Thoughts on tapping DRL fuse?
  19. Feb 18, 2020 at 5:16 AM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    Or posi-tap to your corner light.
  20. Jul 19, 2020 at 11:35 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    Purple wire on headlight is DRL. I tapped that so they run when headlight Stalk is clicked to parking lights or headlights. Easy Peezy
    NewImprovedRon likes this.
