Let’s talk fuel cans
Discussion in 'General Automotive' started by MannFrank86, Jun 17, 2025.
  1. Jun 17, 2025 at 10:03 AM
    MannFrank86
    MannFrank86 [OP] New Member
    Ever since the powers that be forced those rigid pour spouts onto customers, I’ve had a constant low level irritation with fuel cans, both gas and diesel. Well, the time has come to replace my very old gas containers with new ones. I’ve tried the retrofit nozzle kits and half leak when filling the mower, generator, etc. I can’t quite choke down the cost of the sure cans with the nozzle you squeeze with the spout on the bottom. (Currently $76 bucks for one 5 gallon can, but if they work…..)
    I’m now looking at racing jugs with the flexible pvc spouts but there are mixed reviews. I want to believe there’s a better option, maybe I need to take a class at the local YMCA, “Fuel pouring 101”, lol, but I figured I’d see what the rest of you folks are doing in hopes I can eliminate this minor irritant.
    Thanks in advance for your assistance.
  2. Jun 17, 2025 at 10:23 AM
    Cruiserpilot
    Cruiserpilot New Member
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    MannFrank86[OP] likes this.
  3. Jun 17, 2025 at 10:32 AM
    Hauschm76
    Hauschm76 New Member
    melanie
    2009 Tundra SR5
    Battery operated portable fuel pump, no need for a nozzle anymore, lazy but works. I use the jerry cans from HF, the cap seals good.
  4. Jun 17, 2025 at 10:33 AM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Bprose and MannFrank86[OP] like this.
  5. Jun 17, 2025 at 10:48 AM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    I 2nd the utility jugs. Ive had 3 for about 15 yrs now, same ones. Have replaced hoses but thats it. No leaks, no problems.
    However, i hear in CA if you’re caught (BLM in off road areas mainly) its a hefty fine as they are not “carb” certified. They used to call them fuel jugs, now they have to market them as utility jugs.
  6. Jun 17, 2025 at 11:08 AM
    Over the LINE
    Over the LINE New Member
    New Orleans
    2016 Limited CM 4x4 2025 SR5 CM 4 x 4
