Let’s see everyone’s non-HV 12v setup!
Discussion in '3rd Gen Tundras (2022+)' started by kilodelta97, Aug 23, 2025 at 11:51 PM.
  1. Aug 23, 2025 at 11:51 PM
    kilodelta97
    kilodelta97 [OP] 2023 Platinum Crewmax
    Aroostook County, ME
    Black 2023 Platinum
    Hey everyone! Certainly not my first rodeo on upfitting vehicles with lighting and radios. Just trying to decide how I want to layout the auxiliary power setup on my non-hybrid.
    Thinking I’m going to make a nice tray for the engine compartment to house my charge guard, power distribution, relays, and fuse block. Was hoping folks that have done the same can drop some inspiration pics.
    thanks!
  2. Aug 24, 2025 at 3:43 AM
    topdec
    topdec New Member
    AWD Sprinter, 2023 4R ORP, 2 3rd gen Tundras - sold
    Where would your house battery be located in your plan?
    kilodelta97[OP] likes this.
  3. Aug 24, 2025 at 4:43 AM
    kilodelta97
    Black 2023 Platinum
    I have no need for a house battery, no crazy power draws. I’m not doing an overland build, just a daily driver. All auxiliary lighting, CB, VHF/UHF, and emergency lights/equipment (Vol. Fire/EMS).
  4. Aug 24, 2025 at 10:20 AM
    sandiegosteve
    sandiegosteve New Member
    San Diego
    24 Limited TDR Lunar Rock
  5. Aug 24, 2025 at 2:47 PM
    Mallcrl
    Mallcrl New Member
    Anand
    Maryland
    '25 Limited TRD-OR
    I've been without my truck for about 8 weeks at this point, so I have a pile parts and nothing to install them into.
    My plan is to switch over to the SDHQ battery terminals, a single MRBF fuse holder that will then send power to a BlueSea SafetyHub 100 (mounted on an ABS plastic bracket secured to the OEM battery tie down).
    SafetyHub100 will power an ARB dual compressor and the DC-DC charger, as well as a few other accessories under the hood (horn relay, CANM8 IDR8-R CAN decoder, and relay power for the CANM8 high beam output)
    I've been quite happy with making brackets for electrical components out of ABS lately as it's easy to cut and super easy to re-shape using a small butane heat gun, but strong enough to hold up to rough use (I use 1/4" ABS sheets).
    DC-DC charger will be mounted under the cab on the frame rail, and everything else for the aux-battery will live under or behind the rear seat.
    I can add pics... But who knows when I'll have a replacement truck :rofl:
    kilodelta97[OP] and oddhours like this.
  6. Aug 25, 2025 at 12:53 PM
    topdec
    topdec New Member
    Does the plan include components like master breaker/fuse and switch? What is the route for grounding?
  7. Aug 25, 2025 at 8:43 PM
    kilodelta97
    Black 2023 Platinum
    Yes, there will be a breaker to protect everything as well as individually fused circuits….. Have yet to determine where I want to place a grounding buss, and if I’m going straight to battery or not.
    Again, the whole point of this thread was to try and get inspiration from other folks on their layout (including grounding routes) and determine how I want to do mine.
  8. Aug 26, 2025 at 11:19 AM
    Calif-Tundra
    Calif-Tundra New Member
    Bob
    2023 Tundra Limited TRD
  9. Aug 26, 2025 at 12:45 PM
    99ways2die
    99ways2die New Member
    NJ
    2022 Tundra Platinum
    Similar to you, but used BlueSea marine components, and Hella weatherproof replays (for things which need 'em).
