Legit Parts Website?
Discussion in '1st Gen Tundras (2000-2006)' started by DBombs, Dec 24, 2024.
  1. Dec 24, 2024 at 11:43 AM
    DBombs
    DBombs [OP] I Like Old Trucks
    NE Atlanta
    2006 Tundra DC SR5 V8 4x4 TRD
    Has anyone used Toyota Parts Online Depot? They have a part that all the dealer sites show as discontinued, so I am skeptical. I’m looking for the interior front left door handle on a 2006 double cab in dark gray. Part number 74220-0C011-B3 Any input appreciated, thank you
  2. Dec 24, 2024 at 12:17 PM
    shifty` I'm having daydreams about night things
    Toyota Parts Online Depot is Cochrane Toyota in Canada.
    At this point, even if you order the charcoal grey ("B3" in the part), you're going to get beige parts. It's "discontinued" because they're only making beige parts now. You can try ordering from them, no doubt. Maybe they still have inventory up in Canada. Sadly, as much as I tell people NEVER order "OEM" parts on scAmazon and fleaBay, it may be the only way to get this part in the correct color, through channels which may have it in stock.
    But before I ordered from Canada, I'd try www.Partsouq.com or www.Amayama.com which are legit sources, one in the middle east, the other in Japan.
  3. Dec 24, 2024 at 12:30 PM
    DBombs
    NE Atlanta
    Great, thank you for input. I’ve checked Partsouq.com already. I’ll keep hunting and try calling Cochrane Toyota directly. I’m hoping to replace and not repair.
    I’m all ears if anyone else has suggestions.
  4. Dec 24, 2024 at 12:44 PM
    Fragman
    Fragman New Member
    TX
    2006 Tundra DC SR5 2WD V8
    Maybe look on FB Market place for Gen 1's being parted out?
    I had never done Facebook, and only joined it in the last month as I wanted some running boards. There seem to be several FGT's being parted out. Usually they show a picture of the inside so you can see what trim color it has. If I wanted interior parts, I'd at least give it a look.
  5. Dec 24, 2024 at 12:51 PM
    In a pinch, Dorman's part is decent quality.
    I have two I ordered for my access cab in charcoal grey when I realized Toyota was phasing out colored parts.
  6. Dec 24, 2024 at 12:54 PM
    My order.
    And just to check, are you 100% sure your part numbers are correct? Did you look up your part using the sticky partfinder thread in this forum that directs you to the EPC-DATA website which picks parts by your VIN#? My parts here are technically for my access cab but I'm curious if they're compatible with your double cab.
  7. Dec 24, 2024 at 7:46 PM
    DBombs
    NE Atlanta
    Thank you Fragman and shifty. I’m 99% sure about the part number. As I research more on Dorman and look at your part numbers, I realize I should have called what I’m looking for the “door armrest” and not called it the handle.
    The Toyota dealer provided the part number from my VIN. When I look it up on the ETC-DATA site, I locate it on the schematic but it won’t provide the full part number or active link. Presumably because it’s not available? But still, the 74220 prefix matches the part number I was provided. And other sites also match the part number when searched. So I’m 99% confident in its accuracy. That part number again was 74220-0C011-B3. I’ll attach some screenshots.
    Regarding the Dorman parts, have you been happy with quality? I see some other parts on their website of interest, such as headlight assembly and exterior side door mirror assembly. IMG_7775.png IMG_7774.png
  8. Dec 25, 2024 at 7:50 AM
    At the EPC website, you see how it has the words “FIG 14-3”? That should be a link directly to the correct diagram containing the part numbers you need. Give it a shot.
    Dorman quality is generally pretty solid. But I DO NOT recommend buying light housing from them. Have you seen the new owner sticky thread? It contains our collective knowledge on lighting. Housing wise… You want to buy CAPA certified housings, some brands that are usually pretty good are DEPO, TYC, Eagle Eyes, and one other not coming to mind right now. Supposedly the Akkon housings are solid but not CAPA certified. I don’t recommend buying on scAmazon or fleaBay, authenticity is a problem on both platforms.
    Exterior mirror… buy used, dude.
    The armrest piece. Someone else on here bought for double cab. The OEM quality was less than impressive, and supplies were low back then. He beefed his up. I wish I could remember who it was. Siebler? I feel like it was a west coast member, or PAC NW. I can find it later, you probably want to read his post experience before you order new. Or again hit a JY and buy used.
  9. Dec 25, 2024 at 8:12 AM
    Fedtime
    Fedtime New Member
    I’ve used Cochrane a few times, with no issues or problems. However, Canadian Toyota parts suppliers commonly show obscure parts as available when they are not. Best move: email and ask if the parts are available. Most are quick to reply.
    I’ve also used these guys a bunch of times, located in London, Ontario. Toyotapartsdirect.ca
  10. Dec 26, 2024 at 1:13 PM
    DBombs
    NE Atlanta
    Thank you Shifty. Most helpful. I will continue to explore.
    Fedtime, what you said about Cochrane was spot on. I talked to them today and they do not have the part that shows available online.
    I appreciate the help and expertise. Great forum with generous and helpful people. Much appreciated
    Fedtime and Desert Dog like this.
  11. Dec 26, 2024 at 1:45 PM
    badass03taco
    badass03taco New Member
    2005 Limited Double Cab 4wd
  12. Dec 26, 2024 at 1:53 PM
  13. Dec 26, 2024 at 5:06 PM
    DBombs
    NE Atlanta
    Ah so close I’m still hunting. Will get there. Thank you both!
  14. Dec 26, 2024 at 5:23 PM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    Google " Toyota and *part number* "
    it should pull different dealerships that have it available and you can compare from one site.
    I just did this for my alternator lol
    I saved about $100 ordering from Ourisman instead of any of the other dealerships.
    w666 likes this.
  15. Dec 27, 2024 at 12:47 PM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    I got an email from Ourisman yesterday that they have a sale and up to 35% off on parts right now with no code needed.
    shifty` likes this.
  16. Dec 27, 2024 at 1:18 PM
    2020_Tundra
    2020_Tundra New Member
    2020 MGM Platinum
  17. Dec 27, 2024 at 4:44 PM
    DBombs
    NE Atlanta
    Thank you, will include the Sequoias in my searching.
