Left rear turn signal problem
Discussion in '1st Gen Tundras (2000-2006)' started by jaywalkadog007, Mar 31, 2022.
  1. Mar 31, 2022 at 7:47 PM
    jaywalkadog007
    jaywalkadog007 [OP] New Member
    2003 Tundra 6 cylinder standard cab 220k
    None
    All lights and turn signals work fine with headlights off. With headlights on, the left rear turn signal blinks very weak, however, the left brake light also blinks, brightly. I’ve inspected the wiring harness front to back, no visable chafing. Am considering replacing the selector switch. Anyone have any suggestions. Other than that, it runs as good as the day I bought it new in 2003 for $13,500. Thanks for your help. Jim
  2. Mar 31, 2022 at 7:51 PM
    jaywalkadog007
    None
    No, just original bulbs. I tried replacing the bulbs, no luck
  3. Mar 31, 2022 at 8:04 PM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    The taillight harnesses are the same from side to side. Remove both taillights and unplug the harnesses down near the frame and switch harnesses from side to side and see if the issue follows. If it does then and new taillight harness will fix your issue. If not then if you have aftermarket trailer light wiring that'd be a good second place to start.
  4. Mar 31, 2022 at 8:26 PM
    jaywalkadog007
    None
    Thanks, good info. I’ll switch harnesses. Jim
  5. Apr 1, 2022 at 12:28 AM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Make sure the bulbs are all the way snapped in, I had an issue with my blinkers. I didn’t push the bulb in all the way
