Left Front Wheel Noise
Discussion in '2.5 Gen Tundras (2014-2021)' started by Alpine22, Jan 9, 2022.
  1. Jan 9, 2022 at 5:39 PM
    Alpine22
    Alpine22 [OP] New Member
    Greater Houston Area
    2019 SR5
    I have searched through some threads but they all seem to be different. I have a noise at the left front tire that sounds like a nail in the tire ( noise seems to happen at consistent intervals) scraping the concrete each time it touches but quieter. I have checked the tire and there are not any nail, rocks,etc. Took the tire off and there is no apparent debris or anything. When I spin the rotor, there is a consistent spot where it rotates easier for about 10 to 15 percent of the rotation.
    Rotors and pads were replaced about 6 months ago and the tires were rotated 2 weeks ago. I also tried bending the shield back but I don't think that's the problem? Any ideas? Early warped rotor?
  2. Jan 9, 2022 at 5:42 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Does it go away in 4wd? Thinking needle bearing.
  3. Jan 9, 2022 at 5:49 PM
    Alpine22
    2019 SR5
    It's not 4wd and no lift or anything.
  4. Jan 9, 2022 at 5:52 PM
    2mchfun
    Jack it up and replicate it by hand to determine the cause?
  5. Jan 9, 2022 at 6:04 PM
    Alpine22
    2019 SR5
    I did jack it up and rotated but with the wheel off. That's where I get the portion where it spins easier for a small portion of the rotation. Tire/wheel does not appear to be damaged in any way.
    2mchfun likes this.
  6. Jan 9, 2022 at 6:05 PM
    So seems recent from the rotation?
  7. Jan 9, 2022 at 6:10 PM
    Alpine22
    2019 SR5
    Maybe. I have 155k miles on the truck too so some things could be wearing out. I guess I could start with switching the tires and seeing if stops or changes?
    2mchfun likes this.
  8. Jan 9, 2022 at 6:15 PM
    2mchfun
    Maybe a loose caliper, check the bolts, also just for confirmation check the ball joints and shock mounts.
  9. Jan 9, 2022 at 6:17 PM
    2mchfun
    Could definately be a warped rotor.
  10. Jan 9, 2022 at 6:18 PM
    2mchfun
    You could swap the rotors to confirm.
  11. Jan 9, 2022 at 6:34 PM
    Crunch527
    Iowa
    TRD Supercharger/BAM
    What kind of rotors and pads?
  12. Jan 9, 2022 at 6:37 PM
    Crunch527
    Iowa
    If you used aftermarket rotors/pads from AutoZone/Oreillys/Advance/Checker, etc then I would not rule these out.
  13. Jan 9, 2022 at 7:24 PM
    Alpine22
    2019 SR5
    I used Power Stop brakes. Also, don't know if it matters but my truck is a 2012. I don't know how but I put this in the wrong forum and don't know how to move it. But I don't think the year would make too much difference.
  14. Jan 10, 2022 at 3:08 AM
    Crunch527
    Iowa
    That shouldn’t matter that much…it does sound like a possible warped rotor…is the wheel tight on the hub? Like, with the wheel raised off the ground, does it have any play on the hub?
    BTW: I used these brakes too and I think the OEM brakes are better.
  15. Jan 10, 2022 at 3:48 AM
    Hurricane
    Hurricane Default: Aggressive
    NC
    2017 White 1794
    None
    With 155k miles, I would be thinking wheel bearings. But that makes a roaring or grinding noise when driving.
    2mchfun likes this.
  16. Jan 10, 2022 at 6:06 AM
    Alpine22
    2019 SR5
    Ball joints seem Ok (I'm no expert), the shock appears to have a leak but the truck does not seem to be affected by it. I will replace it soon but don't think its the issue. I am starting to think warped rotor or something stuck between the rotor and the backing plate. What is the best way to test/examine the rotor for what may be minor warping?
  17. Jan 10, 2022 at 6:13 AM
    blanchard7684
    blanchard7684 New Member
    brake caliper that is stuck.
    Take the caliper off and depress it inwards. then try again. if the issue is gone then the caliper is getting stuck.
    if the issue persists then try rotating the hub with the brakes off and see if you get same issue. If so then the front hub has a bearing that is going south.
  18. Jan 10, 2022 at 2:13 PM
    Alpine22
    2019 SR5
    Took brakes and caliper off and everything looks OK. Laid the rotor on the flatest surface I could find and it seems flat. Rotated the hub and it turns freely without any noise so it's something with the brakes. Pads could be bad or the rotor could be slightly warped. Doesn't seem to affect the driving any so I guess Ill drive it for another week or so and if it doesn't go away I'll try some other rotors and pads.
  19. Jan 10, 2022 at 3:15 PM
    2mchfun
    I'd swap the rotors to try and narrow it down before throwing money at it. You might spend on rotors only to find a bad caliper or bearing. Diagnose completely then spend as needed. Save $$
