LED's for spyder headlights
Discussion in 'Lighting' started by yoneytan, May 16, 2018.
  1. May 16, 2018 at 7:05 PM
    yoneytan
    yoneytan [OP] New Member
    Asi
    14 CM
    My truck came with Spyder headlights and i'd like to install LED bulbs. Anyone have a link to ones that will fit right in and work best?
  2. May 16, 2018 at 10:54 PM
    yoneytan
    Asi
    14 CM
    anyone?
  3. May 18, 2018 at 2:08 PM
    matictundra
    matictundra New Member
    Franco
    AZ
    2017 Red Tundra SR5 4x4 CM
    3"/1.5" Lift (Fox 2.5 DSC all around, JBA UCA's and Toytec Shackles at 1.5") Front and Rear TRD Sway Bars Nitto Ridge Grappler 37x12.5R18 w/ Brz 18x9 +25mm Methods MR701 Wheels AFE Dry Filter with TRD Flow Acc Dirty Deed No Muffler Exhaust Nitro 5.29 Gears RCI Engine, Trany/Trans-Case and Fuel Skid Plates Relocated Rear Diff Breather | Rear Brake Line Extension Jomax ABS Sensor Armor Colored Matched Front Bulge and TRD Pro Grill Assy Modded ADD Stealth Fighter Front Bumper Custom High Clearance Rear Bumper with Modded Tow Receiver Behind Plate and Chopped Rear Fender Custom Bed Stiffeners 2019 TRD PRO LED Headlights w/ Ihacker Harness | BD 40" ARC AMB/WHT DC OnX6 BD 10" Onx6 in the Grill (2X) Rago Low-Profile Ditch and Extended Brkt with Daul BD Squadron Pros - AMB & WHT AMB LED Chase Light (Cargo) | Dual BD Squadron Sports in Rear Bumper Prinsu Roof Rack with a Pair of BD S1 For the Sides and Rear Mictunning C2 Rock Lights, 2 per wheel, and Toyota style switch 2X 55" Quick Light Whips with Toyota style switch Switch Pros SP-9100 with Custom Switch Mount, Custom Engine and Roof Terminal Junction Boxes 12K Lbs Smittybilt Winch with wireless remote and Factor 55 FlatLink E Amp Power Step EVO-One Remote Start Limo Tint (All Around) | De-Badged LED Interior lights with Front / Rear Interior Footwell LED Blue LED Lit Lock/Window Switch Mod AJT Full Chrome Delete Kit w/ 3R3 Painted SHCS Toyota LED Bed Lights Leather Perforated Wrapped Steering Wheel Black TRD Shift Knob ESP Long Box BakFlip MX4 Bed Cover Thinkware Q800Pro Dashcam (Front & Rear) Rago Dashmount w/ Ram Phone Holder
    I used Hikari LED H11. I got it from Amazon.
  4. May 18, 2018 at 2:13 PM
    yoneytan
    Asi
    14 CM
    Thanks for the reply. What wattage did you use?
  5. May 18, 2018 at 2:47 PM
    Borgs
    Borgs New Member
    PA
  6. May 18, 2018 at 2:54 PM
    yoneytan
    Asi
    14 CM
    Are the H11 for the headlights? Some of the reviews are stating that H4 are for headlights and H11 for fog lights. Just trying to make sure i'm ordering the correct ones. Thanks
  7. May 18, 2018 at 10:25 PM
    matictundra
    Franco
    AZ
    H11 for headlights
  8. Jun 22, 2018 at 8:19 AM
    PMG
    PMG New Member
  9. Jun 22, 2018 at 8:27 AM
    War Machine
    War Machine SSEM # 5 3MW
    They are. I’ve had them in my Spyders since September. I think they take the H11’s. I know for sure it was different from what the factory ones took.
    I’m pretty happy with them. Don’t forget to transfer your leveling motors over to the Spyders.
    PMG[QUOTED] likes this.
  10. Jun 22, 2018 at 10:14 AM
    SullyMoto19
    SullyMoto19 New Member
    Tyler
    Houston, Texas
    2017 Magnetic Gray SR5 5.7 4X4
    8" ReadyLift w/ ReadyLift and Bilstein Adjustable Coilovers w/ Reservoirs, 3" PA Body Lift, Fox 2.0 Shocks, 24x14 RBP Atomics (custom powdercoat Gloss Black), 40x15.5r24 RBP Repulsor, Relentless Fabrication Stealth bumper, N-Fab side steps, Bedlined/Paintmatched Honeycomb Grill, 2019 LED Headlights, 4 Backlit RBG Cubes, 16 RGB PlashLight Rocklights, 5% Tint & Brow, 2 10" Kicker CVT Subs with Kicker Amp in custom sealed box, Husky all weather floor mats, LED White interior bulbs
    i have Heise LEDs in mine.. H11. I can post a pic of the box when I get home
    PMG likes this.
  11. Jun 22, 2018 at 11:04 AM
    matictundra
    Franco
    AZ
    They are plug-n-play. I had mine since January this year and love them. I had been on few night trips, 5 hrs minimum, no issue with heat.
  12. Jun 22, 2018 at 1:19 PM
    PMG
    PMG New Member
    Thanks gents. I was thinking of getting the Hikari Phillips lumileds; a little pricier, but they claim more lumens.
  13. Jun 22, 2018 at 1:37 PM
    Borgs
    Borgs New Member
    PA
    Yes, plug and play. Really easy install. You need to unscrew the top black cap though although I am sure you would have realized that. I am happy with them. They aren't HID's by any stretch, but better than stock. I wasn't interested in running wires in my engine bay.
  14. Jun 22, 2018 at 2:21 PM
    SullyMoto19
    Tyler
    Houston, Texas
  15. Jun 22, 2018 at 2:26 PM
    matictundra
    Franco
    AZ
    Let us know how the install and reliability goes.
  16. Jun 22, 2018 at 2:30 PM
    SullyMoto19
    Tyler
    Houston, Texas
    In stall was easy, plug and play. Output is decent.. but not as good as my previous set up. But I do have projectors and smoked lenses now
  17. Jun 22, 2018 at 3:45 PM
    PMG
    PMG New Member
  18. Jul 11, 2018 at 11:10 AM
    myt1
    myt1 New Member
    Richard
    Scottsdale, AZ
    2010 Tundra DC TRD SR5 Desert Sand Mica
    OME Lift, 275/70R 18
    I just came from the Spyder website and it says: "Adding HID/LED bulbs will void warranty".
  19. Jul 11, 2018 at 11:56 AM
    wigsplitter
    wigsplitter New Member
    DFW Texas
    2018 SR5 TSS Crew Max
    Which is why I haven't bought Spyders since everyone says they halogen bulbs in them are worse than stock headlights.
