LED upgrade
Discussion in '3rd Gen Tundras (2022+)' started by Gasman675, Oct 23, 2021.
  1. Oct 23, 2021 at 1:20 PM
    Gasman675
    Gasman675 [OP] No Carolina Squating here
    South Carolina
    2014 Tundra Crewmax SR5
    6 inch procomp stage 1, and the ugliest rims on earth. Bought this way, there will be changes
    Good evening fellow tundra enthusiasts
    I have a 2014 crewmax sr5 and have purchased OEM LED head lights and a wiring harness. Turnsigal light operate fine until I turn headlights on, then I get the rapid flash.
    Any body have suggestions?
  2. Oct 23, 2021 at 1:24 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Probably should post this in lighting vs the 2022 Tundra forum.
    What wire harness? any other LED bulbs in the truck at all, inside or out?
    1lowlife likes this.
  3. Oct 23, 2021 at 1:27 PM
    Gasman675
    South Carolina
    Thank you I will
    I may have figured it out
    Thanks again
  4. Oct 23, 2021 at 2:52 PM
    Crunch527
    Iowa
    TRD Supercharger/BAM
    Check with iHacker on the 2.5 Gen Forum. I bought the LEDs for my ‘14 and used his harness and it all works great.
  5. Oct 23, 2021 at 3:12 PM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
  6. Oct 23, 2021 at 4:21 PM
    Sounds like you don't have the harness from @iHacker
