LED Under Hood
Discussion in 'Lighting' started by TTU19, Oct 5, 2016.
  1. Oct 5, 2016 at 11:40 AM
    TTU19
    TTU19 [OP] Wreck 'Em
    Wes
    Tx
    2021 TRD Sport
    I want to wire some LEDs under my hood and around the engine bay to light it up when needed and on a weather proof rocker switch under the hood. I wanted to ask just a few questions though from those who know more about wiring and which LEDs to use.
    LEDs: I think the roll up LEDs would probably be best since I can cut them to fit and will stick to just about any surface. I've never used these types of lights though. Would you use anything different?
    Then I'll probably use these solderless connectors:
    Wiring: If I understand this correctly, I run the positive from the LEDs to the ACC on the rocker switch. The Negative I'd just ground somewhere to an existing bolt, or create my own for a ground. The Power from the switch would run to the battery, or tap into a fuse, while the Negative/Ground would just connect to a screw. Can it be the same screw as the LED negative or does it need to be at a different location?
    If I run the Power from the switch directly to the battery, it would technically always be powered, correct? I don't want to have to turn on the truck to use it.
    If you have any other recommendations, please let me know. I'm trying to get all my supplies together that I'll need and ready to install. Thanks..!
  2. Oct 5, 2016 at 12:02 PM
    TTU19
    Wes
    Tx
    2021 TRD Sport
    Also, I've seen a lot of diagrams that use a Relay, what would be the purpose in that?
    Sorry, ha. Newb!
  3. Oct 5, 2016 at 12:03 PM
    Bannock452
    Bannock452 New Member
    Brandon
    Murrieta, CA
    2016 White Crewmax 4x4 SR5
    King coilovers 35x12.50-18
    Sub'd for this one. Seems like your on the right track to me! Look forward to seeing your results!
  4. Oct 5, 2016 at 12:42 PM
    TNTundra08
    TNTundra08 New Member
    Blake
    2008 DC 4x4
    3/1 lift. 20x9 Method standards, machine face. 305/55/20 nitto trail grapplers
    While I am no expert. This is how I wired up two led lights for my truck and haven't had any issues for almost two years.
    For the wiring hardness and lights. Yeah, all my grounds I hooked to the same bolt, I wired my light bars straight to the battery so I can use them even without the key. For what you want that's the route I would go then you don't have to keep your key on "on" or "acc" and can still use them.
    I was told LEDs don't draw that much power so you shouldn't have to worry about draining your battery while working in the bay (assuming that's the need)
    Example: I also changed all my interior lights to LED and left them all on for 3 straight days by accident when I went out of town and the truck didn't even hiccup to start up.
    I'm sure someone with more electrical knowledge will chime in but just to get ya started (with hopefully accurate info) I was letting you know what I did
    TTU19[OP] likes this.
  5. Oct 5, 2016 at 12:43 PM
    TNTundra08
    Blake
    2008 DC 4x4
    And when I say "wired the light bars straight to my battery". I had a wiring harness and relay that hooked from the lights to the harness then straight to the battery. Instead of supplying power through a fuse tap that turns off when the truck it off
  6. Oct 5, 2016 at 1:08 PM
    TTU19
    Wes
    Tx
    2021 TRD Sport
    Yeah, I'll put a small fuse in-line to the battery just to be safe, but I think that's the best way to go.
    @RowdyRon posted this photo of what he did, and is exactly what I want to do. Pop the hood and flip the switch for instant lights.
    SouthBoundSteve likes this.
  7. Oct 5, 2016 at 1:21 PM
    TTU19
    Wes
    Tx
    2021 TRD Sport
    Yes, that all makes sense in order to hook them up. I also didn't think about the heat and such could result in the lights not sticking. Hummm... I had originally thought to put a light on the hood, so overhead. Then somewhere on each side of the engine bay. Wire all 3 together and then to the switch and grounds.
  8. Oct 5, 2016 at 1:23 PM
    TTU19
    Wes
    Tx
    2021 TRD Sport
    Guess it depends on the LEDs that I use, but what size fuse do you think would be needed? 15 amp should be good enough I'd think?
  9. Oct 5, 2016 at 1:24 PM
    TTU19
    Wes
    Tx
    2021 TRD Sport
    Yeah, I'm on Superbrightleds.com right now putting all my supplies together. I'll see what else they have and go from there to check ebay and Amazon.
  10. Oct 5, 2016 at 2:40 PM
    dumbassdave
    dumbassdave Member
    Dave
    2016 Crewmax Limited
    If you used a 15 amp fuse, your wire would would probably melt (or make fire) before the fuse blew. A relay would be used when there is a high current that you wouldn't want going through your switch.
    As an example, on my Tacoma I had a light bar on a factory fog light switch. The switch triggered the relay and the power for the light goes through the $8 relay, not my $50 switch.
    With the LED light strips, I'd imagine that you wouldn't be hitting any current that would be a concern to run through a rocker switch, especially since the rocker switch is likely inexpensive.
  11. Oct 5, 2016 at 2:42 PM
    CJ21
    CJ21 CJ-21
    DELAWARE
    2016 Tundra platinum
    Clifford Alarm, 7" BDS lift with Fox coil overs, 20x12 with -44 off set fuel Mavericks , 35" TOYO Open Country Tires , Bush Wacker pocket fender flare ,2" rear Leaf springs, Bull Bar,
  12. Oct 5, 2016 at 2:43 PM
    CJ21
    CJ21 CJ-21
    DELAWARE
    Check that out that's a lot better than the LED strip light. They're very inexpensive on eBay . Is the LED light Bar.
  13. Oct 5, 2016 at 2:44 PM
    TTU19
    Wes
    Tx
    2021 TRD Sport
    That makes sense, so maybe a 5 amp fuse? Like you said, with the little amount of power, there shouldn't be a worry, but just in case.
    NewImprovedRon likes this.
  14. Oct 5, 2016 at 2:44 PM
    TTU19
    Wes
    Tx
    2021 TRD Sport
    Thanks, I'll check it out when I get home.
  15. Oct 5, 2016 at 2:52 PM
    dumbassdave
    dumbassdave Member
    Dave
    I'd think that 5 amp fuse would be fine. If you really wanted to you could look up what fuse you needed based on the length and gauge of wire you will be running. Personally, I'd just put in a 5 amp fuse.
    Could also make things a bit more interesting and put in a mercury switch so that it turns the light on when you open the hood! I used one on my Tacoma glove box with an LED strip. I found the switch on Amazon.com for about $10.
  16. Oct 5, 2016 at 3:04 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    I have really thought about underhood lights and almost pulled the trigger then I realized I have a Toyota and I will always be in the garage when I need to look under my engine. I won't ever be left stranded with a repair being needed on the side of the road. ;)
    Law323, NewImprovedRon and TTU19[OP] like this.
  17. Oct 6, 2016 at 10:34 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    +1, I tried them under my bed rails on my Tacoma. I ended up using 3M body molding tape. Then the lights burned out after about a year. I changed them out for 8" submersibles.
    CJ21 and NewImprovedRon like this.
  18. Oct 6, 2016 at 10:36 AM
    TTU19
    Wes
    Tx
    2021 TRD Sport
    Thanks for sharing. Yeah, that's probably the route I'm going to go. Just gotta find them and figure how to mount them under the hood.
  19. Oct 6, 2016 at 10:45 AM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    got mine on Amazon. They are made for marine applications. I find that things made for the marine environment are generally a little better
  20. Oct 6, 2016 at 11:39 AM
    SuperSilverTundra
    SuperSilverTundra i didnt pull up i Landed
    Nick
    Los Angeles California
    16 TUNDRA 5.7 PLATINUM-PRO
    3"/1" TOYTEC 18x9 XD818 Heist 295/70r18 COOPER XLT DirtyDeeds BAMuffler 2018 LEDs KatzKin Leather S&B CAI
    looks good
