LED Turn Signals
Discussion in 'Lighting' started by Trddude2017, Oct 13, 2018.
Led turn signals
  1. Yes, your experience with them.
    25 vote(s)
    80.6%
  2. No
    6 vote(s)
    19.4%
Multiple votes are allowed.
  1. Oct 13, 2018 at 7:27 AM
    Trddude2017
    Trddude2017 [OP] New Member
    Gary
    2017 tundra limited blue
    Super chqrger, leveling kit, after market tow minor is and led lights.
    Has anyone added LED turn signals and resistor pack to avoid hyprflash? Any recommendation on any brand?
  2. Oct 13, 2018 at 7:29 AM
    Walters96
    Walters96 New Member
    Matthew
    2014 LTD Blue Ribbon
    TRD Grille
    I have done this. I just simply picked up resistors from Canadian tire (obviously in Canada) but you should be able to get them lots of places
    Trddude2017[OP] likes this.
  3. Oct 13, 2018 at 7:39 AM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    I have added VLEDs to my '18. I have no hyperflash but i had gotten the resistors just in case.
    Before
    After
  4. Oct 18, 2018 at 7:13 PM
    multirc
    multirc New Member
    Ron
    2018 Tundra 1794 Edition
    Thats cool. I been wanting to get LED’s for my turn signals because they are just so damn lame. Its like I always wonderd if the car in the opposite direction could actually see them. So yours dont require resisters? Thats the only thing that was holding me back on getting them because Im not sure how to wire up the resistors. Where did you get them? Thanks!!
  5. Oct 18, 2018 at 8:32 PM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    Built-in-resistors, probably won’t last but they were $30CAD (I’m in Canada too). Ran hazards 10min to get them hot, no hyperflash. I did the DRL amber delete mod so they’re really only on when turning.
    Mountun Goat, Prostar 190 and Rockbox like this.
  6. Oct 18, 2018 at 8:56 PM
    anthonygan
    anthonygan New Member
    2017 Cement TRD PRO
    7in BDS lift, Spyder Smoked Taillights,
    I have VLED switchbacks ! They are awesome !!! I’ll post a pic later tonight !
    KingRob22, Masshole and astro-jason like this.
  7. Oct 19, 2018 at 2:17 AM
    astro-jason
    astro-jason New Member
    2022 CHEVROLET 3500 CC L/B Duramax 10spd
    I have the V-LED switch backs, a little expensive but, all plug and play no modifications needed. White lights for DRL and amber for turn indicators.
    -Jason
    KingRob22 and Masshole like this.
  8. Oct 19, 2018 at 2:20 AM
    bfd300
    bfd300 New Member
    Looks cool! Whats the drl amber delete mod?
  9. Oct 19, 2018 at 8:02 AM
    Turtle
    Turtle New Member
    Tommy
    Louisiana
    18 TRD 4x4 CM MGM
    Aries Side Bars, DeeZee low profile tool box, weathertech mats, TRD RSB
    Have no experience with Headlight Revolution, decided to go with VLED. Truly plug and play. Kit came with all that is needed. I did mine without disassembling the grill, and headlight removal, really not that bad and only took about a hour. Night and day difference and I have the peace of mind that oncoming traffic can see my turn signals.
  10. Oct 19, 2018 at 8:11 AM
    multirc
    multirc New Member
    Ron
    Yeah, I just dont get how Toyota can be so cheesy with these turn signals especially on a big truck!!. I can see if this was my first truck and just accept the way they are but coming from a 2017 Ram, the freakin turn signals were lighting up signs half way down the block. Would you mind sharing where you got your VLEDs from?
  11. Oct 19, 2018 at 8:41 AM
    Turtle
    Turtle New Member
    Tommy
    Louisiana
    18 TRD 4x4 CM MGM
    Bit the bullet and got the Triton V6, the base is machined aluminum. Not cheaply built, VLED has a web site but the application chart at the top of the page will not let you select 2018. "No information available." Emailed sales and they said that the 7443 in amber was the bulb that I needed. Beware, they aren't cheap. But I figured that with the 3 year warranty and the upgrade that it would be worth a try. Could not be happier.
  12. Oct 19, 2018 at 8:52 AM
    multirc
    multirc New Member
    Ron
    Yeah I was on their website before and seen the latest year they had was 2017. I will check out the 7443. Thanks for the info, much appreciated!!
  13. Oct 19, 2018 at 8:57 AM
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    Don't think it's necessary to mod with iHacker's current harness, already built in. Previously, the ambers were on in DRL mode when I first installed.
    I prefer them off for safety. When I turn, it's flashing on its own without the opposing one still on. There's also a quick mod to keep fogs on in DRL too, thread here somewhere.
    TXRailRoadBandit73 and Trooper2 like this.
  14. Oct 19, 2018 at 9:12 AM
    Turtle
    Turtle New Member
    Tommy
    Louisiana
    18 TRD 4x4 CM MGM
    Thinking seriously about doing the rear with the Triton's also. I got their resistor pack with the fronts just to get the plug and play, removes all doubt about wiring. Just haven't got the balls to take the rear light off secondary to possible body scratches yet!
  15. Oct 19, 2018 at 9:24 AM
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    2 torx and pull it off exactly like the vid, done it a couple of times. Had cheap LED reverse, replaced with better ones. Not the body scratches to worry about, those damn tabs seem like they'll break if not careful.
  16. Oct 19, 2018 at 9:47 AM
    Masshole
    Masshole Lovin' The Great North Woods
    New England
    2014 DC MGM 4X4 SR5 TRD
    Got the VLEDS for my truck. Easy install. 70244A54-2D67-403A-A954-EA7CED30F2A0.jpg
    Beep88 likes this.
  17. Oct 21, 2018 at 6:36 AM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    I have these for front:
    http://www.jdmastar.com/product/753...Bulbs-for-Limited-Space-Vehicle-Set-of-2.html
    These for the rear:
    http://www.jdmastar.com/product/778/GX-3020-SMD-7443-7440-LED-Bulbs-Set-of-2.html
    Resistor i used for the rear only:
    https://www.ebay.com/itm/2-PCS-50W-...&_trksid=p2060353.m1438.l2649&redirect=mobile
    I had disable the drl because i do not prefer amber drl. Therefore the switchback led i have will only turn ON white while the parking/headlights are ON. It will switch to amber/yellow when blinker is activated, then switchback to white.
    This mean i do not have any drl during the day.. im in the process of getting these for my drl though.
    https://www.ebay.com/itm/Pair-LED-B...&_trksid=p2057872.m2749.l2649&redirect=mobile
    Only the rear resistors are used, no hyperflash at all. No need for front resistors.
    Hope this help.
  18. Nov 4, 2018 at 7:47 PM
    Midnightcrew
    Midnightcrew New Member
    NorCal
    2018 Crewmax SR5 Version 2.0
    Did you do the rear tail light bulbs yet??? I’m looking at the VLED Triton Rear bulbs but was wondering if I need the hyperflash fix for a 2018 or no fix???
  19. Nov 4, 2018 at 8:26 PM
    Ntmid8r
    Ntmid8r New Member
    2018 Tundra TRD Sport
    TBA
    Sub’d
  20. Nov 5, 2018 at 6:27 PM
    Turtle
    Turtle New Member
    Tommy
    Louisiana
    18 TRD 4x4 CM MGM
    will prob wait till "Black Friday" sales but the plan is to triton the rear turn signals and back up lights and prob down grade for the license plate light.
  21. Nov 5, 2018 at 8:58 PM
    anthonygan
    2017 Cement TRD PRO
    Last year they ran a 25% off Black Friday!! I’m gonna cop some leds for my daily this Black Friday!
  22. Nov 5, 2018 at 9:20 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    Vleds has 20% off today...
    TRD15559 and dcsleeper408 like this.
  23. Nov 5, 2018 at 9:43 PM
    Boosted4runner
    Boosted4runner Join the NRA please.
    WA
    2015 DC MGM TRD Tundra, Kings, 5.7, 2018 front end
    Resi Kings, 35” Trail Grapplers on 18” Methods, ICON Delta Upper Arms, Front-Runner bed rack, Yakima SkyBox16, 2018 honeycomb grill, 2018 LED headlights, plastidipped bumper covers
    Yep - I broke one of my tabs off!
    I was pissed! Lol :D
  24. Nov 5, 2018 at 9:48 PM
    Boosted4runner
    WA
    I’d like to know as wel! I went to order just now and you have to pick hyperflash fix or no hyperflash fix.
    I would assume we need it, but I don’t like to assume.
  25. Nov 6, 2018 at 2:45 PM
    Midnightcrew
    NorCal
    :popcorn: That’s what I thought too.
  26. Nov 6, 2018 at 2:46 PM
    Boosted4runner
    WA
    Anybody? Hopefully the 20% off code still works before we get an answer lol
  27. Nov 6, 2018 at 3:14 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Brake lights you don’t need. Signals you need.
  28. Nov 6, 2018 at 3:26 PM
    Boosted4runner
    WA
    Awesome! Thanks!
  29. Nov 7, 2018 at 7:13 AM
    Midnightcrew
    NorCal
    Thanks BlueBottle!!!!!
    BlueBottle[QUOTED] likes this.
  30. Nov 7, 2018 at 9:13 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Boosted4runner likes this.
