LED strips for bed lighting?
Discussion in 'Lighting' started by JJ_TNDRA20, Oct 18, 2020.
  1. Oct 18, 2020 at 10:22 PM
    JJ_TNDRA20
    JJ_TNDRA20 [OP] JJ
    SOCAL
    2020 TUNDRA TRD PRO SW
    *Wheels/Suspension -ReadyLIFT Plus 2 -ReadyLIFT skid plate adapter -Method MR701 18 x 8 + 25 -BFG KO2 305/70/18 *Exterior -BakFlip MX4 hard cover -Rigid Industries foglight caps *Audio -2 AudioMobile 10 in subs -Sealed dual 10 enclosure -Helix Class D 1 channel amp -Helix 4 channel amp -5 channel Line Out Converter -BLAM audio 6.5s/6x9s/tweeters
    Quick question, I dont have a voltage meter...looking to install some LED strips for bed lighting....does anyone know of a hot wire and ground i can tap into for the these lights...
    Also, as a source, would you recommend the tail lights or the license plate lights???
  2. Oct 18, 2020 at 10:30 PM
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    2022 CMLB TRD OR Prem. 4X4 and 2002 RCLBV65Spd
    Your could try the trailer harness if you want constant.
  3. Oct 18, 2020 at 10:44 PM
    Jonnynewton909
    Jonnynewton909 Jonnys_Tundra
    Jonny
    East Texas
    2017 Tundra CrewMax
    Accutune Fox DSC 2.5 front w/ SPC UCAs, Alcan custom spring pack and Accutune Fox DSC 2.5 rear. 37 Toyo RT Trails on Method 312s. SOB Fab F&R high clearance bumpers. AT Overland Atlas.
    Does your truck not have the OEM bed lights? If it does, that would be easy to tap into. If it does not, maybe the wiring is there for the addition of the factory bed lights???
  4. Oct 24, 2020 at 11:57 PM
    JJ_TNDRA20
    JJ_TNDRA20 [OP] JJ
    SOCAL
    thanks...went straight to the battery...
  5. Oct 25, 2020 at 4:28 AM
    Zero One Actual
    Contact @mattgecko and he will square you away with whatever you need.
    HulkSmurf14, grichg and mattgecko like this.
  6. Oct 25, 2020 at 5:55 AM
    biebs96
    PA
  7. Oct 27, 2020 at 10:04 AM
    Charliebrn
    Charliebrn New Member
    NW Ohio
    2017 DC Limited 4x4 Tundra
    Tyger Folding Tonneau cover Polished stainless running boards LED interior lighting VLED Footwell Kit LED Bed lighting
    Another thumbs-up for the MattGecko bed lights. Awesome lighting without blinding you.
    HulkSmurf14 likes this.
  8. Oct 28, 2020 at 3:30 PM
    TxTundraAustin
    TxTundraAustin New Member
    2019 Tundra TRD Pro
    Looks great! Would you mind sharing which wire you tapped into? Im guessing the loom is on driver side?
    Thanks!
  9. Oct 28, 2020 at 4:04 PM
    biebs96
    PA
    On a 19 I’m not sure what wire it will be.
    On a 17 it was a thin brown wire in the driver loom.
  10. Oct 30, 2020 at 7:33 AM
    Kevfran99
    Kevfran99 New Member
    Kevin
    Lilburn, GA
    '19 TRD PRO
    TRD Rear Sway Bar - Front tint - Caliraised LED Fogs & Light Bar-Bed LEDs-Bed Cover-Wireless Charger
    Do you have bed rails? I ordered these and they're too long. Could you post of couple day pics of how you have them attached. Thanks
  11. Oct 30, 2020 at 8:27 AM
    Beesta
    Beesta New Member
    Jay
    Loudoun County
    2019 Pro Midnight Black Metallic
    How are you turning it off when you don't need it ..?
  12. Oct 30, 2020 at 10:49 AM
    biebs96
    PA
    I will post them tomorrow. It will be dark when I get home tonight.
    They fit on the tonneau cover rails perfectly.
  13. Oct 30, 2020 at 10:52 AM
    Charliebrn
    NW Ohio
    The MartGecko kit had a waterproof toggle switch included. Drilled a hole under and to the rear of the rail on drivers side, which is exposed when you take the taillight off. It’s easy to reach with the tailgate down and out of the way of most cargo.
  14. Oct 30, 2020 at 11:08 AM
    Beesta
    Beesta New Member
    Jay
    Loudoun County
    Oh im good... thanks ... i put one in my bed already but i followed how the factory lights schematics. I was just wondering.
  15. Oct 30, 2020 at 11:47 AM
    JJ_TNDRA20
    JJ_TNDRA20 [OP] JJ
    SOCAL
    it came with a switch...
    Beesta[QUOTED] likes this.
  16. Nov 2, 2020 at 2:02 PM
    Kevfran99
    Kevin
    Lilburn, GA
    '19 TRD PRO
    any chance to get a pic?
  17. Nov 3, 2020 at 4:55 AM
    biebs96
    PA
    Pardonmyn00b likes this.
  18. Nov 3, 2020 at 5:49 AM
    Kevfran99
    Kevin
    Lilburn, GA
    '19 TRD PRO
    Thx as I figured you don’t have the deck rail system. These are a bit too long for the deck rails. I don’t think they’d say attached.
  19. Nov 3, 2020 at 7:21 AM
    Kevfran99
    Kevin
    Lilburn, GA
    '19 TRD PRO
    ordered the MattGecko bed lights since they require the deck rails for install. will report back once I get them installed.
  20. Nov 6, 2020 at 1:33 PM
    Kevfran99
    Kevin
    Lilburn, GA
    '19 TRD PRO
    Did you run the bed led positive to the cargo lamp wire?
  21. Nov 6, 2020 at 1:37 PM
    Kevfran99
    Kevin
    Lilburn, GA
    '19 TRD PRO
    If you did could you please show of pic of which wire you tapped? Thanks
  22. Nov 6, 2020 at 1:44 PM
    biebs96
    PA
    I did. The wire is located in the driver side sill plate. But I know the color will not be the same as on my 17
  23. Nov 11, 2020 at 7:43 AM
    Kevfran99
    Kevin
    Lilburn, GA
    '19 TRD PRO
    Matt Gecko led bed lights. Very pleased with them. Bright enough but not blinding. Quality product!
    MyActualName likes this.
  24. Nov 11, 2020 at 8:18 AM
    sotex
    sotex Sic 'em Bears!
    Jeff
    San Antonio, TX
    2020 White Tundra SR5 Double Cab 4x2 SX
    Just ordered my @mattgecko lights for the bed and hood. How easy/fast is the install?
    vipgs3 likes this.
  25. Nov 11, 2020 at 8:24 AM
    Kevfran99
    Kevin
    Lilburn, GA
    '19 TRD PRO
    depends on if you run them like the directions say with his switch. I didn't. I ran mine to the cargo light which caused me to have to run a relay. All in all not bad
  26. Nov 11, 2020 at 8:31 AM
    sotex
    Jeff
    San Antonio, TX
    Hmmmm. Now I'm trying to decide which I would prefer. I think a switch would be great if I were just in the back and wanted it on. Switched to the cargo would mean any "auto off" would turn off those lights too, correct? Whereas a switch would be dedicated.
  27. Nov 11, 2020 at 8:45 AM
    Kevfran99
    Kevin
    Lilburn, GA
    '19 TRD PRO
    Your cargo light switch is auto, on, or off. Yes mine is set to auto currently so when the cargo lights kick off the bed lights do too. But if I plan to be back there for a while just flip the interior switch to on.
    sotex[QUOTED] likes this.
  28. Mar 31, 2021 at 7:24 PM
    dooododoo
    dooododoo New Member
    MGM '17 CM OR
    Fortin EVO-ONE Remote Start iBoard Running Boards (Black 5") LED interior lights Line-X Bed Plasti-Dip Emblems
    How did you run the wires from the driver's kick panel to the bed? I assume the wire would be running under the truck to somewhere in the bed? Where does the wire exactly go from kick panel (interior) to under the truck (exterior)? And then where exactly does the wire come into the bed? Near the driver tail light?
  29. Mar 31, 2021 at 10:34 PM
    Pardonmyn00b
    Pardonmyn00b New Member
    2018 Cement Tundra
    I just did the Amazon led kit and it’s awesome! Ran a power wire from the battery as I plan to have more power options mounted in the bed in the future. have a hidden push button waterproof switch to turn them on and off.
    I did not want them run off my "bed lights relay" because I didn't want them to turn on and off all the time during the day.
    I ran it down from the battery along the frame tons of room, convenient my dad has a 2 post lift in his shop. I should have taken some pictures of how I ran the wire.
    E909D4ED-F7D1-4A91-B537-3792424933D0.jpg 89B71664-7AB3-4B4B-835D-B38057511CF6.jpg
  30. Apr 4, 2021 at 11:25 AM
    dooododoo
    MGM '17 CM OR
    For the guys that tapped into the cargo light wire at the driver's door.... where did you connect the ground to?
