LED signal flasher
Discussion in '2nd Gen Tundras (2007-2013)' started by Tim98TA, Mar 18, 2024.
  1. Mar 18, 2024 at 11:22 AM
    Tim98TA
    Tim98TA [OP] New Member
    I searched but all I came up with was old threads about soldering in resistors to the OEM ones. Has anyone figured out/bought a replacement flasher setup that cures hyperflash?
  2. Mar 18, 2024 at 12:29 PM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    You can't just replace the flasher relay on Tundras because it is electronic.
    The best resistors I've found are VLED resistors.
    They tap into the OEM wiring, no soldering is needed.
    Just mount them behind the tail light.
    Resistors Cancellers - Products (vleds.com)
    redrdr67 likes this.
  3. Mar 18, 2024 at 12:39 PM
    Tundra1D6
  4. Mar 18, 2024 at 1:55 PM
    mtucker
    mtucker New Member
    Escondido CA.
    2008 Double Cab
    Listed in my build thread
    I looked around about a year ago and I could not find an off-the-shelf LED flash module/relay to replace the OEM one. They are out there for many years of Tacomas. I wound up changing the current sense resistors in the OEM flasher module (up under the dash near the emergency brake in my 2008). About 0.15 Ohms is a good starting place. If of course depends on how much current your LED turn signals are pulling.
