LED low beam install help needed on 2nd gen
Discussion in 'Lighting' started by K1NJO, Sep 3, 2019.
  1. Sep 3, 2019 at 11:06 PM
    K1NJO
    K1NJO [OP] New Member
    Allen
    Bay Area, CA
    2011 Black Tundra TRD Sport
    I got the fog lights and high beam LEDs installed, but I'm having trouble with the low beams. Because the LED unit is fairly large, I need to unscrew the headlight housing in order to get a little more room to wiggle the LED in. How should I be removing the panel below the headlight? I removed the two push tabs at the left of the panel, but how do I remove the actual panel? I feel like I'm gonna break something when trying to pull it off.
  2. Sep 4, 2019 at 12:02 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
  3. Sep 4, 2019 at 3:08 AM
    K1NJO
    Allen
    Bay Area, CA
